This is not meant to make you look foolish ,but as a warning to others
Thats why you disconnect the battery when doing this kind of work
agreed... from now on.
so here's what I figured out yesterday from the shop I stopped at in CT:
there is power at the brake sensor, but none at the back of the car. They think that I fried a wire (well, i think its wires since i dont have parking lights either) somewhere in the middle of the car. How can I go about testing where the break is? Guess and check every foot or so (i guess this means ripping out the interior, right?)?
Thanks for the help in advance..
Chris
If you have compromised the wire, your best (and safest) way to remedy it is to completely replace said wire(s). Doesn't mean rewiring the entire car, just replacing that specific wire in the harness. Definitely not a job for the faint of heart, and certainly an expensive lesson. Those who follow will be wise to learn from yours. Good luck.
Big Mack
I think I will be attempting to work on this tomorrow. Does anyone have a wiring diagram for the GS? wiring colors? pretty much I have to rip out the entire interior correct?
So can you shift now? A bad tail light wire should not affect your shifting ability.
Yeah He can shift fine but no brake lights. I met up with him when He got to CT. He actually drove here from Queens with no brake lights. Hazard lights in traffic FTMFW
Cool. That's good news, 1 of 2 issues fixed at least. I take it that it was a fuse issue causing the shifting problems?
Give me till tomorrow - I will get you whatever wiring diagrams you need.
You are definitely the man, I figured you'd chime in sooner or later... if you have them in PDF or something, I will give you an email address to send em to.
