Instruction for Factory HID Bulb Replacement
Old 09-10-17, 09:05 AM
  #91
jodyfletch
jodyfletch's Avatar
Best write up on this on the whole interwebs. Thanks for Texas!
Old 09-13-17, 08:37 PM
  #92
MDMXLX
MDMXLX's Avatar
Thanks for the write-up. Wish I'd had this before attempting it in the parts store parking lot!
Has anyone found a good LED conversion kit for a GS400 equipped with HIDs?
Old 09-14-17, 06:27 AM
  #93
XenonDepot
Former Sponsor
XenonDepot's Avatar
Are you looking to go from HID headlights to LED? That would honestly be a downgrade as LED conversion kits produce less light than a HID bulb or kit.
Danny
Old 09-14-17, 06:41 AM
  #94
MDMXLX
MDMXLX's Avatar
Danny
Thanks to your comparison shots, I've realized this. The car is 100% stock so there's no reason to go LED other than the "cool factor". The electrical system isn't being bogged down by a big stereo or an air bag suspension (compressor).
Thanks again!
Old 09-14-17, 09:19 AM
  #95
AmanO
AmanO's Avatar
LED can output more than HID. You can get a cleaner light and color temp and it would be easier to match other LEDs to it.
The problems are the beam pattern and going from a proprietary harness to LED. I also have not seen any kits that have LEDs that fit OEM HID bulb sockets.
I want to do this, so I would want to get a set of halogen housings and either only tap off the power or use a relay.
Old 02-23-20, 01:45 PM
  #96
PaulaB
PaulaB's Avatar
What does the bulb look like? I am afraid to pull the bulb out until I get the condensation issue fixed. I am told the moisture it the reason the light burned out. Thank you for any tips/advice. I just bought this 2005 rx330 and didn't think the light issue would be so complicated..
Old 01-11-24, 06:50 PM
  #97
SonofaLexusOwner
9th Gear
SonofaLexusOwner's Avatar
Default Replacing Drivers Side Low Beam HID Bulb
Outstanding tutorial on how to replace the factory HID Bulb. Can anyone provide any recommendations on how to access the driver's side low beam bulb?
95BlackToy
09-28-11 12:52 AM
IneedLexus
02-12-10 08:42 PM
w1ck3d64
08-10-09 10:25 AM
rominl
Lighting
03-21-03 04:50 PM
Jmill427
08-30-02 01:52 PM
Quick Reply: Instruction for Factory HID Bulb Replacement
