Heated Seats - Dealership Issue
...working at a lexus dealership, i can tell you this. The seat heaters work off of the inside and outside air temps. The colder it is outside, the warmer your seats will be. On a 50 degree day they wont be near as hot as they would be if it was -2 degrees. Also there are only 2 things that can go wrong, the switch or the element. If the element is coming on then the switch is working. If there is continuty in the element, more times than not, it is ok. I had one the other day that was shorted internally and it got too hot.
Thanks for the info. I went outside last night when it was 32 degrees. Turned the car on and sat in there for about 5 minutes. I didnt feel a thing. Not sure what is going on. They replaced the heating element and checked the switch and fuses. Good thing spring is on the way.
iModerate
You will feel the seat heaters more when its cold outside but only because the difference in temp is greater. The air temp has nothing to do with the seat heater function. Check the wiring diagram. Straight from fuse to switch to heater. No temp sensors are involved. I have even seen a GS where the seat was 10 degrees cooler but felt warmer because it was outside vs a GS sitting inside that was 10 degrees hotter in a warmer environment but didnt feel as warm as the car that was sitting outside. Also, I have noticed that if the seat covers are perforated they seem to be thicker and dont get as hot as a standard leather seat cover (IMHO).
![Agree](https://www.clublexus.com/forums/images/smilies/iamwithstupid.gif)
Mine, as I stated above, are cooler in the mornings (5AM Pacific - 45°ish lately) and warmer at lunch / go home time (11am - 2pm - 60°ish). Total opposite of what I need.
