rear differential issue
so my car have been getting the 'clunk' noise from the rear differential for a while whenever i shift into drive/reverse or anything else. i had my car serviced at a lexus service shop for a rear differential leak a while back but i don't know what is the problem now. Does anyone know?
thanks in advanced.
thanks in advanced.
check and make sure its not the rear pads sliding or coming unseated instead of being a differential problem...i SWEAR i just saw a post of this a few days ago but at this moment (too busy to look for him) i cannot find it. will leave tab open and when i catch up i will look if no1 has found it yet
edit found a post but not one im looking for
https://www.clublexus.com/forums/sus...of-my-car.html
Like what people have said in prior post. The first thing you want to check is rear differential. I'm not sure if the dealership remove the axles out when they fixed the leak, but when you remove the axle from the differential, you want new gaskets that the bolts attaching the axle to the differential. This is similar to your oil drain plug gasket where it crushes down when torqued down to spec. Next, you wanna check to see if the driveshaft is bent or not as this can contribute to the noise. Lastly, if this doesn't solve your problem, open the rear cover on your differential to check if you had alot of runouts from the gear.
i got the car fixed when i still had my powertrain warranty but it was over last september
DGNY2009
11-13-12 01:20 PM
