How do I install my rear lip spoiler?
I have had a nice TTE rear lip spoiler for quite some time now and I need some advice on how to install it. It's not one of those skinny (strip) lip spoilers it is approximately 5" wide. Do I just glue it down? If so, what type of glue? Will it hold? Should I have it professionally installed?
Thanks
Thanks
3m adhesive tape and it won't go anywhere. Just make sure the surfaces are cleaned and it would be a good idea to rub the areas where the tape will be with alcohol to remove and dirt/wax/residue. If you aren't sure how to do it I would just let a shop do it
I would have to disagree with you guys. Stay away from the 3M adhesive. Use something stronger. I had a lip spoiler ripped right off my trunk a few months back and I did everything Rich suggested.
https://www.clublexus.com/forums/gs-...me-people.html
sorry to hear that... did it come off with the wind or someone ripped it off???
i agree that it is not going to stop a thief ripping off your lip spoiler... it is above and beyond what 3M is capable of holding on but unless the lip spoiler is designed to be screwed on or has clips, this is probably your common option for installation...
the 3M is still strong enough to hold the lip on at 100 mph+...
If you want to be able to ever remove the spoiler put it on 3M tape the shop type though not the cheaper ones. If you dont you can glue it down using 3M Window Weld and that thing is not going anywhere, but if you ever want to remove you would probably damage the spoiler and need to repaint your trunk to get rid of the adhesive.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Ju can read about it hyah!
Big Mack
flashbang
04-25-05 06:54 AM
