Emblems
been a member here for probably about a month or two, although i havent posted much given the fact i have been extremely busy at work.
I searched around this thread a bit, and my question has "sort of" been answered, although there is alot of input and i want to see what you guys feel works best.
Took off the GS300 and the LEXUS eblem on the trunk. The emblems came off easy, and the glue from the GS emblem wasnt that bad taking off.
As far as the LEXUS emblem, i can not get the glue off the trunk! I have been using 3M adhesive remover and as i stated above, it worked fine taking off the residue from the GS. I must have sprayed and wiped the LEXUS side 25+ times, and i still have the outline of glue that says lexus lol.
Which product do you guys feel is best for taking this off?
I recently did this aswell. The glue part was baked on to the car. I used goof off and bug/tar remover..(make sure its paint safe) I soaked the sticky remains for a min or two then I used my buffer to slightly agitate/remove the glue VERY slowly LITTLE at a time. After that i used a wax and sealant to seal the deal. Came out FLAWLESSLY.
hope this helps gl.
hope this helps gl.
thanks for the input, i will try all mentioned. as far as the clay bar, i clayed my car about two weeks ago...while i was claying the areas i did it until it feld smooth and all the contaminents were off. after washing the car again, i felt the paint, and it still feels rough??
i was using the meguiars clay bar w/the meguiars lubricant
Didnt wana start another thread.... but my emblems say 300GS instead of GS 300
I thought maybe some body work was done, but had a friend check it out and no body work has been done, any reason its backwards? lol
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
