Help hood release...oil change
Old 02-26-09, 09:33 AM
mydakrri
mydakrri's Avatar
Default Help hood release...oil change
I"m at a Quick Lube right now, got my oil changed, and now my hood won't shut tight, can I drive with just the safety latch?. I can't search the forum from my phone. Any quick ideas???
Thanks
Dakrri
Sent from my BlackBerry® wireless device from U.S. Cellular
Old 02-26-09, 09:38 AM
aido
aido's Avatar
You can drive, just don't speed!
Saying that mine held up to 80mph once when I'd forgotten it wasn't shut properly.
If it's the same problem I had where the lever in the car stays open as well it should shut itself soon when you hit a bump in the road or if it's really stuck you'll need a new cable - part no 53630‑30250 from the dealer
kit cat
kit cat's Avatar
facing the car (standing in front of your car with the hood open) theres a wire to your right, underneath the sticker, right behind your driver's side headlight (IIRC....). Pull on it, then try closing it.
Old 02-26-09, 09:41 AM
aido
aido's Avatar
That's a good point - that wire I quoted the part no for is from a RHD car but assume LHD is the same as the diagram in the EPC was showing it as LHD.
Old 02-26-09, 09:59 AM
mydakrri
mydakrri's Avatar
Thanks guys
I'm going to use a few platic wire-ties, straped around the grill and through the bumper facade, to get me back to work and then home. Sounds like I have a weekend project ahead of me. Dang-it
Have a good one....dakrri
Old 02-26-09, 10:05 AM
kit cat
kit cat's Avatar
dude, it only takes like 5 seconds.
Old 02-26-09, 10:16 AM
kamlung
kamlung's Avatar
could also be that the cable is stuck... try lubing it first...
Old 02-26-09, 10:22 AM
HGill
HGill's Avatar
I had the same problems a couple weeks ago, I pulled the hood release inside the car firmly a couple of times and it closed.
Old 02-26-09, 10:30 AM
mydakrri
mydakrri's Avatar
Ooooopps Sorry...I forgot to mention I did try that and it didn't work.
They had 6 cars waiting behind me so I had to go. And to be honest, I didn't want these guys tring to fix it. The one guy came out with a hammer to hammer the latch. I told him to get another hammer, because evertime he hits the Lexus, I'm going to hit him. What a Dm-A$$
Thanks again....
Old 02-26-09, 10:35 AM
Frankdorn
Frankdorn's Avatar
That's funny. What part of WI are you in?
Old 02-26-09, 11:22 AM
sakataj
sakataj's Avatar
funny when i bought mine...on the 1800 mile drive home i added oil and couldnt get it changed so i went to a oil place and had it changed,blades replaced,air filter and it shut for them fine but happened to me again SEVERAL times so i just replaced the cable. its a common problem for our gs!
Old 02-26-09, 11:51 AM
mydakrri
mydakrri's Avatar
Sheboygan...40-miles north of Milwaukee.
Waiting for a large snow storm that is suppose to hit in an hour or so.
Old 02-26-09, 01:20 PM
Kyle Harty
Kyle Harty's Avatar
Thanks again....
Have fun with that, probably the same one that just came through MN. Snowing really hard and fast with a bunch of thunder. I brushed off my windows and by the time I was done they were completely covered again. Couldn't see a warehouse 1/2 a block away!
Old 02-26-09, 01:58 PM
Rippaflow
Rippaflow's Avatar
Had this happen on mine and it was broke from the open lever. Took my car to Toyota to do ball joints/tie rods and they fixed it without even telling me LOL. Came out to my car the next day to check my oil like that's whats up LOL
Old 02-26-09, 02:36 PM
Big Mack
Big Mack's Avatar
Smile
Good call on that one. You toucha da car, I breaka you face.
You can both have fun with that flaky white crap. It was a balmy 87° here yesterday. Going to be up over 90° over the weekend. Spring is sprung!
Big Mack
Quick Reply: Help hood release...oil change
