so i reset my ECU the other day.. & now i'm randomly having problems starting my car
there were two particular times where my car wouldn't start and i had to take the negative terminal out and then it started up
what could it be? my starter? or a terminal problem? i know it's not my battery
sorry for the late response.. no crank or lights at all
i'm pretty sure the terminals were just loose.. i wiped them off and tightened up again.. hopefully i won't have any more problems
i apologize for the n00b question! 0=)
ok so it's still doing it =/ the battery was actually turning off while i was on the road because my radio kept shutting on and off..
i seriously don't know what to do because i wiped those terminals and tightened them as well as i could
that happened to me once in he middle of an round about.... ca just turned off.. luckily it turned on after 5 min... of trying ... later i realized that my connection was loose
bought some corrosion cleaner and cleaned the terminals off again.. let's see if this does the trick (although i'm pessimistic)..
what if it's the alternator? how would i know?
the ground was definitely loose.. over-torqued more than likely
bought the metal brush and cleaned terminals.. corrosion spray and gel.. re-tightened and did the wiggle test.. the car has been fine the past two days.. so i'm knocking on wood
