reverse signal avic help?
Old 03-05-09, 12:06 PM
bigjez
bigjez's Avatar
Default reverse signal avic help?
Does ant1 know were it is or were i can find it.
Old 03-05-09, 02:10 PM
corkycal
corkycal's Avatar
are you asking where to tap the reverse signal on your aftermarket nav? if so, just route the wire from the headunit to the reverse light would be easiest.
Old 03-05-09, 02:16 PM
sam430
sam430's Avatar
That's a lot of work (Although I planned for it just in case I can't find it on the console).
Old 03-05-09, 02:37 PM
bigjez
bigjez's Avatar
Thanks to 4play4dr I have found it i did run the wire along the side of my drv. side to the tail light and spice into the pink/blue wire hope this helps someone else as well.
Old 03-05-09, 02:38 PM
sam430
sam430's Avatar
What? you're going that route? I could have told you that! LOL.
Returd
Performance & Maintenance
03-19-17 05:48 AM
loveslexus
10-07-14 06:42 PM
sjlexus408
10-11-12 02:11 PM
corkycal
14
12-02-07 07:35 AM
buttnekkid
11-22-07 08:04 PM
Quick Reply: reverse signal avic help?
