Here are some pics of an unpainted cover. As you can see the cover mounts using the original mounting tabs as the OEM mirror. It has a two wire hook up so when your turning signal is off the LED's are also off, they only flash when your turning signal is also flashing.
Very nice! This is a good mod. So you work with the factory on this? Any chance of getting a Folding Mirror replacement like the Aristo for our US GS models? This would be an even bigger sell than this one.
How extensive is the installation? Do i need to solder wire or open up the door panel? Thanks.
Check out post #3 of this thread, The guy made a DIY on how to install but it was on a 3rd-Gen. I think he mentioned that there was soldering involved.
