How do you replaced rear license plate bulbs?
Old 03-07-09, 03:29 PM
Och
Och's Avatar
Default How do you replaced rear license plate bulbs?
On my 1st gen GS the bulb covers were held in by screws, but on the 2nd gen I dont see any screws? Do I have to take apart the whole trunk to get to them?
Old 03-07-09, 03:32 PM
john_papa
john_papa's Avatar
oh you just have to take out the clips for the trunk lining, and pull it off. you should then be able to locate the bulbs in order for you to replace them
Old 03-07-09, 03:35 PM
CK6Speed
CK6Speed's Avatar
If you have the newer trunk with the emergency trunk release handle on the trunk lid, the trim plate around that handle is a PITA to remove. It is possible to just bend the liner down enough to access the lights, but even with my small hands it was much easier if you remove the entire liner.
Old 03-07-09, 03:36 PM
Och
Och's Avatar
Genius engineers....
Old 03-07-09, 06:42 PM
tom steele
tom steele's Avatar
you have to remove the liner not that bad
Old 03-07-09, 06:54 PM
UpstateLex
UpstateLex's Avatar
what bulbs are you putting in and where did you get them?
Old 03-07-09, 07:07 PM
UncleRay
UncleRay's Avatar
You have to open your trunk, remove the carpeting, twist the bulbs counter clock wise, and voila!
Old 03-08-09, 05:36 AM
Och
Och's Avatar
I wanted to install polarg m4
Old 03-08-09, 05:50 PM
ak11
ak11's Avatar
Och, put led in.
Old 03-08-09, 06:29 PM
CK6Speed
CK6Speed's Avatar
So what trick are you guys using to remove the hard plastic trim around the emergency trunk release handle? Every time I remove it, it feels like it will crack and snap in half. I did it twice, now I just left the trim piece off since I have been removing that liner often.
Old 03-08-09, 06:38 PM
Och
Och's Avatar
Originally Posted by ak11
Och, put led in.
Leds are not as bright as regular bulbs
Old 03-08-09, 06:39 PM
sam430
sam430's Avatar
LOL...mine cracked and snapped. I'll glue it or let it be.
Old 03-08-09, 06:40 PM
sam430
sam430's Avatar
I don't know..but my LED is nice and bright. Looks good with LED.
Old 03-08-09, 06:43 PM
UncleRay
UncleRay's Avatar
Use a pair of pliers. Works great all the time.
Old 03-08-09, 07:17 PM
Euro09
Euro09's Avatar
tell me this is not bright enough for u lolz. I just installed those today . This LED is looks so good in person.
http://i230.photobucket.com/albums/e...o/IMG_0059.jpg
http://i230.photobucket.com/albums/e...o/IMG_0058.jpg
Quick Reply: How do you replaced rear license plate bulbs?
