Signal Flasher relay?
So as many know I have sequential LED turn signals on my GS. The problem is when I use the turn signals, I get hyperflash. I do NOT want to run resistors, but how else can I fix the hyperflash? Do they sell aftermarket flasher units? If so, how easy is it to swap out?
I do not have the problem when using the hazards, only the turn signals.
Chris
Chris
Here are a bunch
http://v-leds.com/BlinkerWarning-Fix...orLanding/true
Also on
http://www.superbrightleds.com/flashers.htm
Just got to find right replacement for the GS.
Also on
Do you know which is the correct one? This is coming from someone who doesnt know too much past wiring an aftermarket headunit. I know it will clip right in, but who knows which one
I too want to do LED turn signals, but i would like if some one could take a pic of the fuse box and circle which is the proper relay to replace.
V-LED.com also sells a relay but i dont know if its the right one.
http://www.v-leds.com/BlinkerWarning...57253-1-3.html
The relay is located under the driver side kick panel..it's a pain in the but to get to. It's a little above all the fuses and it's clipped on to the fuse housing.
looks something like this:
you will lose confirmation blinker when you lock the doors with your remote however youwiill still get the beep.
get the one posted above me.
Let me know if you lose the alarm confirmation... I bought the toyota one with the same number on it...this one is for the lexus. The toyotat one's says you will lose the alarm confirmation but the lexus one didn't say so. I think I will buy this one too if you get the functionality back.
As an aside - If I could run my aftermarket LED tails (parking/brake lights) without the resistors, I would - and I tried, and ended up blowing up my brake failure sensor module. That was a nice 250 dollar present to myself.
So if I can get an exact link to something that would work, that would be awesome!
edit: just saw the one sam430 posted, i will be ordering tonight
BTW.
You just need one relay...the one I linked is for 4 led ... that relay is for LED blinker for front and back. If you do just two, you might have to get a different relay.
Just pull the old one and replace with the new one. It has a clip on the fuse box...and the relay itself has clips on both sides.
