Gs400 radio/sound clipping....
Hey guys, im new here... Love the site... I have a quick question.. I had my lex(2002 gs400) for a while now.. But lately for some reason when i turn up my radio the sound is clipping in and out... Anyone ever had this happen??? N if so any ideas what i could check or fix the problem...
Thanks!
-dan
Thanks!
-dan
when i got my GS,it did the same thing, i installed the aftermarket dvd player using the factory amp worked out great, turns out the factory's headunit output was burning out.
common problem on the lexus is the factory amplifer. located on rear right corner do to moisture.
can I install an after market amp easily? and if so... is it easy to replace the stock sub in the back??? Sorry for being such a newwbee.... just wana get it fixed...asap....
mine does this when im bumping music with a lot of bass for 2 hrs straight. after it cools down, its fine again. i always thought it was the amp getting too hot, are you saying the head unit is the culprit we todd it? i've got the Nak.
dartom
08-08-11 04:52 PM
Lexusalex
11-25-06 04:52 PM
