laggin at 4000 rpm
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
I noe I should of searched around but im on my sidekick and it loads really slow. But any ways my lexus is laggin at 4000 rpm once I try to rev it all the way it trips out n doesn't seem to go any were.. What can it be? How much would it be to fix it?
Thx 4 the help C.L..
so you floor it and engine sorta seems sluggish and seems like its about to take off....does it ever take off? it seems like you describing the sluggish DRIVE BY WIRE system our cars have but a misfire, clogged fuel injector or something else going on with it seems more likely....ne CEL lights?
CEL would go on if injectors, plugs, timing are bad. But I think it's clogged cat. The third cat. Because that one has no sensor to monitor it. How many miles do you have on your car? It even could be your transmission. But if you said it backfires, I think your cat is clogged.
If itz the 3rd cat. How much am I looking to spend?
and i OP hadnt said if he had CEL's when i asked him bout injectors/plugs/timing
ClubLyfe
IS - 1st Gen (2001-2005)
09-23-17 11:13 AM
Johnnyy
07-07-17 02:17 PM
