Crank pulley holder
Crank pulley holder
Hey does anyone have a crank pulley holder I can borrow / rent. I'm looking to do my timing belt in the next week. Let me know. I'm located in Seattle. Thanks.
You don't need one.
Get a chain wrench and some thick rubber tubing from the auto parts store.Slice the tubing down the middle, and slide it over the chain then zip tie the ends. Once you do that just put it over the crank pulley and have someone hold it while you use a breaker bar and a extension pipe to break the bolt free. The rubber will prevent any damage to the threads of the crank pulley. I would also have torch handy so you can heat up the bolt nice and hot before yanking on it but you may not need it.
You don't need one.
2) The chainwrench mether is rather difficult, plus most chain wrenches don't come in sufficient diameter.
The chain wrench is easy to find, I bought mine at Harbor Freight for about $15, it was an off the shelf item. You can try to use a breakerbar and bump the starter, that is usually about 50/50 for me, I have had that work on some cars but on my personal car it didn't budge the bolt. If you try that method and are comfortable with it you should try to have a jumpbox or if all else fails another car (running) hooked up to your car so you have 100% of the needed amperage available for the starter as it is going to need everything it can get. Also, only bump the starter for a second, don't hold it, just hit it for a second and let go, if it doesn't work after a few tries it's most likely not going to work at all.
As far as a pulley puller, it would be a good idea to have one handy. There isn't much space between the pulley and the radiator/condensor so you are very limited to how much leverage you have. You can *try* to stick a breaker bar between the pulley and the timing belt cover but it is plastic and unless you get lucky it won't provide the leverage you will need to move the pulley (and you risk cracking your cover). As a tip, the bolt threads on the crank pulley are not a standard thread so whatever bolts come with your puller are most likely not going to fit into the holes unless you make them. Do yourself a favor and go by a Fastenel (sp?) with the car and grab a few bolts of different lengths to use with your puller or else you are going to be cursing when you go to pull it off after have the bolt loose and don't have the proper bolts to do it (you can't get them at Home Depot/Lowe's etc... either). You can try a "claw" puller but those are a pain to use and 90% of the time will just bend the claw arms before they start moving the pulley so I wouldn't waste my time on those.
Btw: WHEN YOU PULL THE PULLEY OFF DON'T LOSE THE KEYWAY!!! (little thing that looks like a halfmoon, most of the time it sticks to the crank but sometimes it will just fall off). Don't forget to remove the timing belt guide before pulling the belt, little guide held on with 1 10mm bolt so it doesn't get bent. There are some tips for you
ef9
Performance & Maintenance
07-29-18 05:33 PM
dashan
21
03-10-18 02:25 PM
