Another retrofit question
That is not the problem. The problem is that the ecu is right behind the driver's side highbeam so there are only a few inches to work with.
So for anyone with projectors in the high beam housings what projectors did u use?
javier....and lee....i talked to adrian (bluelex) this last week and this is what he told me he retroed into the highs
"I had the high beams retro'd with hella 90mm projectors, basically same as what comes in m3's..."
Lee
yeah he should be able to measure off my spare pair of headlights (i'll soon have ANOTHER spare pair thanks to nigel that im actually gonna retrofit on, might even grab up a set of green tinted ones and retro them...guessing im becoming a headlight ***** as i now have 3 sets an thinking of getting a 4th)
i know....i might do 2 retro's....one with the ls430's and the hella and the other with the gatlins and the small gatlins for the high beams! change them out whenever i choose
Anyone with info please help.....
Lee
some people are wheel *****s....im to broke to be spending that much $ on wheels all the time....plus then i would have to do suspension....
all in due time though
Well then there's nothing we can do for him until he's ready. How many sets of headlights does a man need to have before he realizes things are getting unmanageable?
On a side note, I haven't uploaded those Q45 output pics yet, after quite a bit of stress and back and forth I've decided to just use them myself. The other set of projectors I wanted don't look to be available anymore and I want to get the car back together ASAP. I'm hoping to have the first one mounted in the next day or two but I want to take my time and make sure I get everything right. I'll try to get the pics up sometime soon, just for referance if nothing else.
denial schmial. i neither confirm nor deny anything....i take the 5th!
i actually had though bout doin more than that....one with the q45 and fake high beam q45's, one with ls430's, one with s2k, one with tsx, and another one im not mentioning yet
i got some tricks up my sleeve for the ones i do end up...im sure after building ONE set i will have enough parts to make 3-4 other sets so maybe i will do that
so i know others on here have done retro's what did you people do in your high beams?
ok i found a older thread...i like those ls460's think i might swing to them. so what are people doing in the high beams though or are they not doing anything?
https://www.clublexus.com/forums/lig...rojectors.html
