Play in steering wheel after caster arm and daizen steering rack bushing install
So I installed new caster arms or lower control arm #2 and also installed daizen steering rack bushing now there is play in the steering wheel. The steering wheel is also not lined up straight either. Its slightly to the left for the car to be able to go straight forward. If I center the wheel it would move the car to the right. The steering does not feel like it was when it was with oem bushings. Loose and I have a lot less control over the car now. Maybe I should switch them back.... Any ideas of what happened? Could I have damaged the steering rack some how when I installed the bushings?Would it just need a alignment to correct everything? Thanks in advance guys
You can't change caster manually, but if the bushings were worn, and you got an alignment, the toe will be set for that certain caster angle. Once you put in new bushings, your caster should be corrected, however your toe will be off again
And touching the tie rods will definitely change things. Though I never had to touch any of those when I put in my caster arm yesterday
alright just got back from doing the alignment and it corrected everything. Now the steering feels very firm. The daizen steering rack bushing made a big difference. Thanks guys for all the help
BoostAddct
Suspension and Brakes
17
10-28-11 09:29 PM
