euroline dh offset
Old 03-30-09, 02:59 PM
irshad
irshad's Avatar
Default euroline dh offset
hi
i found a set of wheels . the specs are:
front 19x9.0+38 std disk
rear 19x10+38 st disk
my question is:if one day i decide to upgrade the calipers to the ls430 ones or others brands, can these offset cause problems?
what is the maximum size rotors can i use in front and rear with std calipers?
thanks
Old 03-30-09, 03:25 PM
chrispy
chrispy's Avatar
It's not the offset that is the problem, it's the disk of the wheel that determines brake clearance. My brother is running the same wheels with the same specs and it's close to the stock brakes already. If you want to upgrade brakes, you need to get some spacers. A 15mm spacer should do it.
byefi
03-28-18 08:39 PM
gp1300r
10-28-15 08:06 PM
GS3fiddy
09-08-15 05:10 AM
IronCobra
Wheels, Tires & Brakes Forum
05-31-07 08:16 PM
boostedny
05-19-07 12:44 PM
Quick Reply: euroline dh offset
