Quick Question about Ichiba vII 20mm Spacers
I want to install the Ichiba version II 20mm spacers for my rear. Will these spacers clear the stock studs or will they stick out?
I have searched throughout the forums and I found out that it does clear for the IS, but I didn't get a clear answer for the GS.
Thanks for the help!
i had a 25mm h&r and it fit perfectly on the front using oem wheels... 30mm in the rear using project kicks. I dont know about 20mm though. Although, it makes sense that it would stick out to a maximum of 5mm (emphasis on maximum).
I'm assuming you want to use oem wheels? check out if there is any indentation on it.
Rich27
Wheels, Tires & Brakes Forum
03-31-09 11:00 AM
