First tomer (timing belt) did a search and need advice
Old 04-08-09, 07:56 AM
cbibb
cbibb's Avatar
Default First tomer (timing belt) did a search and need advice
I just recently picked up a 99 gs300 and after pulling the inspection cover (chasing an oil leak) found that my VVTI pulley is leaking. I did alot of searching and saw the write ups and I unerstand that you CANNOT move the cams or crank once the belt has been removed. How do you remove the VVTI pulley without moving the cam? While I am in there I want to do as much maintenance as possible. I understand from searching that cam seals/valve cover gaskets/water pump/timing belt/drive belt/spark plugs all need to be done at the same time. What else is needed? Are the cam seals on the end of the camshafts (on the front)? Are there any special tools needed to install the seals? I saw from searching that you need a special took for the crank pulley (balancer) where do I get one of those? I am familiar with v8 american engines but I have never worked on a foreign car? Any advice is GREATLY appreciated. Thanks
Old 04-08-09, 08:13 AM
JoelGs
JoelGs's Avatar
You can find a DIY in the search section of this forum. They tell you what kind of tools to use. Its a good idea to have all those parts replace at the same time but not necessary. The only I would do that is to eliminate the labor rates. Did you picked up this 99 from a private owner? should check all the maintenance records to see what else he/she'd done to the car first before getting it. Look in Search my friend..!!
Old 04-08-09, 09:11 AM
FrankT
FrankT's Avatar
I keep the belt on to loosen the VVT-i pulley bolt, while using a wrench to hold the intake cam, same with the exhaust cam gear.
Even if the belt is off, the cams will not move very much using a wrench to hold the cams.
Cam seals are under the front bearing caps. Remove the bearing caps, remove the seals.
Install the cam seals (after cleaning everything nice and clean) and install the bearing cap over the seal. The bearing cap requires a 2mm bead of silicone sealant before the install and double check the seal is square in its seat.
Check out my post New valve cover gasket, cam seals and VVT-i pulley
Old 04-08-09, 01:55 PM
cbibb
cbibb's Avatar
What other seals/tools etc will I need to add to this list
Timing belt
Water pump
vvti pulley
cam seals
valve cover gasket
spark plugs
drive belt
Where can I get a balancer puller (or what tricks are there to get it off? Thannks
Old 04-08-09, 02:09 PM
FrankT
FrankT's Avatar
Timing belt replacement:
http://mkiv.com/manual/manualtt/timi...t_replacement/
https://www.clublexus.com/forums/show...ub+replacement
https://www.clublexus.com/forums/gs-...-gs-300-a.html
Old 04-08-09, 02:25 PM
Jason T
Jason T's Avatar
Works shop manuel - Repair Manual / ENGINE MECHANICAL / TIMING BELT / INSTALLATION
http://bahamutcars.free.fr/workshop/...nts/index.html
This is what you need to know to set VVTI Inlet pulley for 2JZ VVTI
Originally Posted by JeffTsai
Once you put the VVTi pulley back on, advance it all the way to the right(clockwise) till it stops turning. At this position is what you use to line up the timing marks on the pulley with the notch on the back metal cover. So, dot on intake pulley match to exhaust side dot on the pulley, or line to line. Match it up to crankshaft accordingly.
Remove timing belt, and turn the VVTi intake Cam gear as far clockwise as you can (you may want to turb it back and forth to loosen anything stuck - if it is stuck) Finish by turning it all the way clockwise without disturbing the camshaft. when the VVTi cam gear hits the stop point... make note of the timing mark. if its off. keep the VVTi cm gear turned all the way clockwise and now you have to rotate the camshaft counter clockwise to get the line up notches on the cam gear to match the cam cover.
Some pictures can be found here
http://www.toymods.net//forums/showthread.php?t=42745
Crank shaft pulley tool required / how to remove
Old 04-11-09, 04:05 PM
cbibb
cbibb's Avatar
Thanks guys, I appreciate it!!
beno
09-21-15 03:32 PM
moat
02-12-12 04:25 PM
handzilla
06-06-11 07:00 AM
leggman1
05-02-11 05:29 AM
milellie11
06-22-10 10:21 PM
Quick Reply: First tomer (timing belt) did a search and need advice
