need ur help... fuel gauge stuck
my fuel gauge will not pass the half way mark...
if i fill up my tank the fuel level will go up but it will not go lower then the half way mark.
i already replaced my speedometer and fuel pump assembly with leveler and the orther leveler but its still doing the same thing.![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![](http://http://i.ebayimg.com/19/!BPVEDs!!Wk~$(KGrHgoOKkEEjlLm(0GPBJzDor6l4!~~_1.JPG)
when 1st got my car there was not much gas in the tank and the gas light was on this is on a 00 gs300.
please help... thanks
the reason why i replace the fuel pump assembly is cus i thought that there was only 1 lever but i guess there is 2
anyone know where the fuel gauge level is located? do i have to drop the whole tank to get to it?
i think i need the leveler on the bottom of the pic
well i've heard of cases like these, ussually the tanks are filled with about 10 kilos of dope! which cartel/drug seize you buy your car from? haha ! its your floaters in the tank Jcat Gs3 is right , my boy had the same issue !
ok i found it... its located under back seat on the right side. thank you guys for all the info... i guess thats what i get when buying this car for only $1400.
still not working...
please help
please help
Bump does any one have a solution to this problem i am now just expiriencing the same exact problem. Gauge has been tested, sending units have been replaced, and floater is new. This problem started to happen after my fuel pump was replaced. I just took it to the lexus dealer to have them trouble shoot it and after 3 days they cannot figure it out. they told me it can be electrical and can cost 200 for the test alone plus 125 for the initial check. anyone have any solutions?
