who run after martket tweeters?
04-11-09, 12:09 AM
did anyone run after market tweeters? and what size and did you guys run component speakers system or just the tweeter straight to the amp?
Can you guys also give me the specs of your speakers your running too, cuz i know the Gs can fit bigger then 4"
04-11-09, 12:19 AM
I have Mb Quart Reference Premium in 6.5", factory mounting location for mid and tweeter.
04-11-09, 12:33 AM
Quote:
Originally Posted by
macd7919
so are you running component speakers or just speaker?
04-11-09, 12:56 AM
macd7919
I'm running components.
04-11-09, 03:18 AM
Front I am running Polk Db6501 6.5 Component set and rear I am running PowerBass 3XL 6.5 inch components, cut the tweeter into the rear door panels.
04-11-09, 09:20 AM
Spyder78
where did you cut your rear tweeter too? and was it a direct fit for 6.5 or did you have to use brackets?
04-11-09, 09:37 AM
I'm running 1" tweeters off of an amp. They're mounted on the A-pillar. I'm running 6.5" for midrange which is also getting its own amp.
04-11-09, 10:40 AM
GSteg
is the A pillar where the stock tweeters are at?
04-11-09, 11:26 AM
close..but it's the part where your windshield and door glass meets. I located it up there for a higher soundstage.
04-11-09, 11:31 AM
GSteg
so what you do with your oem tweeter holes?
04-11-09, 11:36 AM
Nothing. OEM tweeter is still there. No reason to touch it since it's not connected. There is a grill to cover the OEM speaker so nothing looks out of place.
04-11-09, 11:49 AM
GSJDM430
any speaker you have to fabricate a adapter for, I used MDF and fabricated an adapter. The rear tweeter is cut into the upper part of the back door towards the front but angled back to the rear seats.
04-11-09, 12:22 PM
can someone help my find alpine component speakers that will work on my front door please (=
i'm new to this and crutchfield is confusing.
04-11-09, 01:28 PM
Why Alpine? What are you going to power the speakers with and what headunit will you be utilizing?
04-11-09, 04:38 PM
Spyder78
im gonna run oem navi with the jl clean sweep and JL amp, and im trying to keep my sound system within JL audio and Alpine only
