VSC/VSC OFF problems
Old 04-13-09, 12:16 PM
ss915
ss915's Avatar
Default VSC/VSC OFF problems
Hello all, I'm new to the forum. First off, I have a 1999 Lexus GS300 with about 53,xxx miles on it. On a recent trip I noticed that the VSC and VSC OFF lights came on at the same time. I noticed that the car does this only when I make a right turn and the pavement is uneven. What could be the problem? Also the lights stay on until I turn the car off then turn it back on. However, they will turn on again when I make the same turn. I don't think it's anything big but just checking. Dealer said they would have to do a diagnostic at $100 and $100 for each additional hour!!!!
Any help would be appreciated. Thanks.
Old 04-13-09, 12:34 PM
AsGs300
AsGs300's Avatar
there are plenty of threads on this issue , heres one i found , might help you even though i dont know if your car is dropped
http://https://www.clublexus.com/for...-question.html
btw 53k on a 99 GS ! wow !
but if you search more you'll find more on the vsc issues
hope i helped
Old 04-13-09, 01:04 PM
ss915
ss915's Avatar
Thanks, I'll check out the link. Yeah I guess it used to belong to some little old lady Car is stock height, haven't messed with suspension at all. I don't plan on messing with it either.
Old 04-13-09, 01:21 PM
AsGs300
AsGs300's Avatar
http://https://www.clublexus.com/for...n-and-off.html
heres another one see if this helps!
bought from an old lady? those are always the best finds! kept in good condition i bet
Old 04-17-09, 04:13 PM
ss915
ss915's Avatar
HELP HELP!!!!!! Checked the wires out, they look good.
Any other suggestions????
Old 04-17-09, 04:15 PM
ss915
ss915's Avatar
Like I said, they only turn on every now and then, not all the time I make a turn. The dealer said it was because the car senses it starts to skid, but they turn on when I'm making the turns slowly also. Besides if the car was really skidding, wouldn't only the VSC light turn on, not both the VSC and VSC OFF lights???
Old 04-17-09, 04:18 PM
ss915
ss915's Avatar
Oh yeah, I'm getting the following codes too..
I got the following codes coming from diagnostic
C0226
C1231
C1223
C1224
Anyone know what they mean and how I can go about fixing?
Old 04-19-09, 10:16 PM
tom steele
tom steele's Avatar
if your wheel bearing goes out if lets the grease in the abs sensor area and grease gets on the sensor and on the gear the sensor reads making if unable to read to check take a 10mm socket and remove the sensor behind the brakes remove and check to make sure both sides are clean i just encountered this same problem
Old 04-22-09, 09:48 PM
ss915
ss915's Avatar
UPDATE...thanks for the advice guys. I took off the sensors and noticed the two front ones had white grease on them. I cleaned them up and cleaned the grease inside. The rear ones didn't have any grease on them. I got excited thinking this would fix the problem, so I went to the infamous right turn where the lights always come on...THEY CAME ON AGAIN!!!!!!! I tell you, it only happens when I'm making the turn and the pavement is uneven. Weird because I was making those kinds of turns before without any problems.
Any other suggestions???????
Old 04-23-09, 12:34 PM
duby1
duby1's Avatar
I'm having this problem too!!!, but mine stay on at all times...
What does it mean?!?!
Old 04-23-09, 12:35 PM
duby1
duby1's Avatar
oh yea, mine is an 99 with 103k miles on it.
Old 04-23-09, 12:56 PM
AsGs300
AsGs300's Avatar
Stop making Right turns! make 2 left turns!.. j'k dude i gotta 99 gs with 184k miles and this issue has been killing me, mine is and on/ff issue not sure what makes it come on/off..
Old 04-24-09, 06:26 PM
AristoKing
AristoKing's Avatar
1999 Lexus GS300 with about 53,xxx miles on it. damn this car never went nowhere huh.
Old 04-24-09, 11:42 PM
Alexus_300
Alexus_300's Avatar
Remove the wheel on the the front passenger side. remove the innner fender linner and disconnect the ABS sensor from the connector. Now go and find yourself a multimeter. Test the sensor and if it register 1.6-1.7k ohms, then your sensors are good and it's something else. If your sensors are not within that range, then it's a defective sensor.
Old 04-25-09, 04:40 PM
tom steele
tom steele's Avatar
yea i would check the sensor like alexus said changing the wheel bearing and cleaning did it for me but thats weird it only when you make rights its not pulling the or rubbing it somewhere my tire rubbed thru the wires once witch caused the lights to go on an off all the time till i found the short. other than that you got me stumped
Quick Reply: VSC/VSC OFF problems
