Car sluggish, have theories, need help to diagnose
Old 04-17-09, 01:29 PM
GS4_Fiend
GS4_Fiend's Avatar
If it is rattling, then your cats are no more good. There are a total of 3 cats. Check to see which one is bad by hitting the cat. If it makes noise, that is the one.
The PCV is the hose connected from the valve cover (driver's side) to the intake.
The fuel filter is in the fuel tank.
Old 04-20-09, 04:59 AM
slickgt1
slickgt1's Avatar
Thanks. So the PCV is the entire hose, or does it have a valve and a hose. Just asking as I never looked for it on this car.
Does anyone know which size and length aftermarked cats I would need?
Old 04-20-09, 12:21 PM
PHML
Master Thread Closer!!
PHML's Avatar
I dont have the service manual for the GS430....only GS300 and GS400.
Here is the PCV Valve for the GS400....should look similar for your GS430.
Good luck.
Pete
Attached Thumbnails Car sluggish, have theories, need help to diagnose-gs400-pcv-valve.jpg
Old 04-20-09, 09:52 PM
skperformance
skperformance's Avatar
This thread has a lot of ideas but very little of practical theroy of why it might be happening.
It is not your cats since the car still revs up just slower. Plugged cats restrict the rpms not the horsepower.
Skip the try this and don't do that's.
Take the car to a technition who has a proper break out box who can monitor the signals from the tach , throttle position , maf and otherwise to tell you exactly what the problem is in 10 minutes.
Old 04-21-09, 06:11 AM
slickgt1
slickgt1's Avatar
Thanks Pete.
This thread has good ideas, especially replacing the parts that have never been replaced, even better since they are cheap.
Techs will cost more than a PCV valve and fuel filter, which I wouldn't even think about replacing without this board. My buddy at Lexus can monitor all of this, but I would need to take a day off from work to drive up to NJ for him to do it. That is just not feasible right now. I need to try and solve this on my own for now.
As far as plugged cats, if I look at the tach when taking off, the rpms jump about 500rpm, then pause then start to go back up very slowly.
Old 04-21-09, 06:23 AM
Och
Och's Avatar
Dude, when if you make it here tonight, we can swap MAFs, and see how your car runs with my maf. I have a feeling that its your MAF.
Old 04-21-09, 06:52 AM
slickgt1
slickgt1's Avatar
Werd, lets do it. Do you have tools, or should I bring them? Thanks man.
Old 04-21-09, 06:56 AM
Och
Och's Avatar
Its just two or three screws.
Old 04-21-09, 07:03 AM
slickgt1
slickgt1's Avatar
I know, but last time I cleaned my MAF, I had to use vise-grips to get the screws loose. Hey do you manybe want to come to my house? I have a garage, and we won't get wet. I'm on X and west 2nd.
Old 04-21-09, 07:12 AM
Och
Och's Avatar
Nah, dont worry, I got plenty of tools here.
Old 04-21-09, 08:18 AM
slickgt1
slickgt1's Avatar
cool. Tonight then.
Old 04-21-09, 09:51 AM
sakataj
sakataj's Avatar
vise grips? they do make screwdrivers my friend. i just cleaned my MAF on my 2001 gs430 and not even sure where u woulda used vice grips...
vice grips=FTL
screwdriver=FTW
hehehe
Old 04-21-09, 12:00 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Rock-a-Lex
Yea I have a feeling I'm heading in that direction as well. The only problem I have with this, is that I am not getting any codes at all. I really don't understand how this can be. The only thing I can think of is that all the oxygen sensors are bad, and the car is thinking everything is ok.
Did you change your cats out? Did you go stock or magnaflow? Thanks.
Never changed my cats out...depending on if I keep the car longer than 1-2 more years then I WILL invest in new cats; they will be direct fit ones...I think made by Catco if I'm not mistaken. Made for the GS and no where near the cost of the OEM ones...GL!
Old 04-21-09, 05:47 PM
slickgt1
slickgt1's Avatar
vice grips=FTL
screwdriver=FTW
hehehe
Ha ha you're funny. I know, I really couldn't break the screws loose with a screwdriver, just kept stripping them. Once I broke them loose, I used a screwdriver.
Rock-a-lex, do have a part number or something.
Och, tried calling you. Your phone goes to voicemail. Where are you.
Old 04-21-09, 06:23 PM
Och
Och's Avatar
Dude I just got home, I had to shoot somewhere. Wanna meet up tomm afternoon?
Quick Reply: Car sluggish, have theories, need help to diagnose
