It just started recently but it seems like there is a constant whining coming from the power steering pump after the car has been sitting for almost 3 weeks.
Anybody know what it might be?
Low fluid? bad pump?
Try changing fluid if not low. Then see if sound is still present. Then you may try changing again to see if you can save the pump. Usually pump is going up if no low level.
