Clean Your MAF
Old 04-24-09, 01:04 PM
  #31
GS300ToM
GS300ToM's Avatar
Yes siRRRRRRr....
Old 04-24-09, 01:27 PM
  #32
vwynn
vwynn's Avatar
ok so some update..
my car stalled twice.. -_- ugh.. WHY!!!!!!!!!
Old 04-24-09, 02:40 PM
  #33
BigVIPness
The Green Grundel
BigVIPness's Avatar
Would polishing the throttle body help at all? I'm going to be cleaning it with the MAF this weekend and i'm wondering how much that would help. I stalled yesterday at a stoplight and almost got hit by a dumb impatient ***** on her cellphone, now i'm all freaked out about driving it.
Old 04-26-09, 10:03 PM
  #34
skperformance
skperformance's Avatar
Cleaning the throttle body is basic maintance.
It removes carbon that is left when teh engine is turned off and the burnt air has no where to go. So it fills up the intake manifld and throttle body.
It causes low idle/stalling ,sluggish throttle , slightly reduced performance caused by turbulance associated to carbon build up.
Cleaning the MAF will show increased power , and milage by making the engine work more efficiently since it now knows exactly how much air is coming into the engine so it can add fuel accordingly .Same as trying to add 2 lbs of sugar to a cake instead of 2 table spoons.
All I can say is that cleaned MAF sensor + cleaned throttle body + new spark plugs + SRT Intake with ECU is giving me a good 5mpg or so better. It's a significant difference.
Well , yeah ?!?!?!?
But their is no "IT" as you mention. That is a combination of maintance items so no one thing can be the one to bring a conclusive result because of association.
So , hopefully this will give some of you some insight as to what is really happening and why and dispel the rumours of untold power gains from teh same people who have intake pipes breathing hot air inside their engine bays.
Old 04-26-09, 11:04 PM
  #35
Billh2
Billh2's Avatar
Anything on the MAF, dust, a slight amount of oil and the MAF is prevented from doing its job, which causes the engine to run lean. This unit is very simple to remove and clean. Unplug the connector, remove the two Phillips head screws, carefully pull out the MAF, squirt some cleaner on it, wait a few seconds until the cleaner evaporates, and re-install it. Before there was a cleaner especially made for the purpose, we used spray carb cleaner, I have talked to guys who used brake clean with good results. Anything that doesn't leave a residue.
The whole point of this thread is to make GS users aware that this simple, quick and cheap procedure can fix a condition that can go un-noticed for a long time and make a big difference in fuel economy and power.
Old 04-26-09, 11:44 PM
  #36
skperformance
(just to expand it a bit more for most to understand what and why)
The more air that passes over the filament (wire) of the maf , the cooler it gets which means the more fuel will be used.
Adding dirt over the maf will stop the filament from being cooled thus the engine thinks less air is coming in causing it to not add as much fuel and then run rich.
As mentioned before ,the ecu will see the values and use a heat cycle to burn off the dirt by itself. You can clean it and beat the cycle but it will happen anyway. Also mentioned uless you have some reason to clean it like a over oiled filter it will look after itself.
So as this is good for a quick boost in performance , so is disconnecting the battery.
The over all value of the idea is valid but so is washing your car in the rain. It is still going to happen with or without you.
A more valid point would be to replace the maf every 150 000miles as the readings are no longer as accurate as they once were.
My feelings are to replace the coolant temp sensor, the maf and both pre o2 sensors for maximum performance and milage as they are the most important variable sensors on a car. They also all wear out and do not throw codes as the ecu will try and compensate for them ageing.
Old 05-12-09, 02:02 PM
  #37
Billh2
Billh2's Avatar
Cleaning the MAF on my car resulted in an increase of almost 3 MPG, from 17.2 to 20.19 on the last tank.
Old 05-12-09, 03:32 PM
  #38
vwynn
vwynn's Avatar
is that freeway or street?
ive been getting 20.5~ mpg before the MAF cleaning and after the MAF cleaning haha.. (Freeway)
Old 05-12-09, 04:09 PM
  #39
Billh2
Billh2's Avatar
That's a combination of city and freeway. Strictly higway miles, I got 23.5 at 75 MPH before cleaning the MAF. Don't know if cleaning the MAF will affect the highway mileage. Cleaning the MAF made a difference on this particular car.
Old 11-07-09, 09:43 PM
  #40
fasted1953
fasted1953's Avatar
I have a 99 gs400, and got a check engine light caused by the MAF. If I replace it, do I need to take any other steps for calibration, etc.? Thanks.
Old 11-07-09, 09:58 PM
  #41
dxb_8788
dxb_8788's Avatar
i cleaned mine before maf and TB and it was big diff. smoother idle better response and better fuel milage
before cleaning it my idle was around 500rpm sometimes 400rpm and shakes crazy i have to say it oil and dirt was blocking like 5% of TB soo always i loose battery coz no enough rpm to charge it i also changed the battey for nothing
who say thats if your idle low i know automaticlly the TB will open more but what if its blocked with oil or greasy dirt
Old 11-08-09, 05:40 PM
  #42
edro925
edro925's Avatar
Has anybody read the instruction on the back of the CRC MAF cleaner. It says something about do not use this on lexus and toyota supra MAF. I should have taken a picture of it.
Old 11-08-09, 05:46 PM
  #43
fasted1953
fasted1953's Avatar
I saw that too. Went ahead and did it anyways. Too soon to tell if it made a difference, but certainly nothing went wrong so far. Somewhere in these forums I saw an explanation of the different types of MAFs, and I think it said the GS400 was one of the kinds that was ok to clean.
Old 11-08-09, 06:23 PM
  #44
Och
Och's Avatar
This is true for first gen LS, GS and SC, and MK3 Supra. These use a Karman Vortex sensor that can't be cleaned without damage.
Its perfectly safe to clean 2GS hotwire MAF. But in reality, unless you're running a K&N or another oiled filter, you should never have to clean it. It is true that some tiny dust/dirt particles will pass through any filter, but K&N filter will cause your intake piping and MAF to be covered with a thin film of oil, and this dirt will stick to the oil. And with a hotwire MAF, that wire heats up to 400 degrees, and that oil and dirt really bake onto it. When I had the K&N for about a year, and I took the MAF out, there was a visible buildup of dirt on it that looked like ear wax.
Old 11-15-09, 09:39 PM
  #45
ta1972
ta1972's Avatar
after cleaning the maf,made my car run smoother and quicker throttle response.
Quick Reply: Clean Your MAF
