Help! Climate Control not working
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
hey im new, my names Alex, Im 17, I have a blacked out gs300 with aftermarket radio and soon subs as well. I have had a problem with the climate control module for quite some time now, it turns on and says its on full blast but nothing comes out of the vents, only a little bit from the defrost vents below the windshield/ help please...
also my radio gets alot of alternator noise i dont know if its the ground for the amp in the trunk? its bolted to the latch thingy above the spare tire.
thanks
i will get pics up soon
thanks
check the blower unit...
and as far as your alternator whine... it is due to a bad ground... check to make sure that you have a CLEAN ground on the wires on your amp in the trunk... the paint should be sanded off for a clear contact to the metal when you bolt your ground wire up... i would also check the ground on your headunit... if you can, run another ground wire separate to the one on the harness and tie it into something metal on the body of the car...
nickCT
12-28-07 12:21 PM
