Simple Fuel Filter Change How to.
Old 04-27-09, 06:24 AM
slickgt1
slickgt1's Avatar
Default Simple Fuel Filter Change How to. Pics Added
************PICS ADDED BELOW*****************
Ok so I changed the fuel filter. Nothing hard here, just a few things people should know.
1. Make sure you have less than half a tank of fuel before you start this. I was too excited to get to it, and had about a gallon of fuel on the garage floor.
2. Tools needed. A 10mm socket, an 8mm socket, and a flat head screwdriver.
3. Take off your rear seat bottom. You just yank on it on the driver side and passenger side.
4. The pump is on the drivers side, so take that 10mm and unscrew the 3 10mm plastic nuts that hold down the cover.
5. You will see a plastic plug, the easiest way to remove it, push on that plug release that faces the front of the car, and push the entire plug towards the back of the car.
6. You will see a metal tube going into the next cover. There is a yellow and white clip holding that tube in place. You take a flat head, and push the yellow part of the clip towards the passenger side, you need to take it out all the way. So when that clip gets stuck, you will need to take your screwdriver, and release each of the two arms on the clip. Don't just try prying it or something, it doesn't need much effort.
7. Take the 8mm socket, and unscrew the 9 bolts holding the pump assembly in there. Slowly pull out the entire thing.
8. There is a hose attached to the filter housing inside, just move the clamp down, and undo the hose.
9. Once inside, it is pretty simple to get the filter out, you will have to unplug the pump wire harness inside (you can use a pick, or just undo it after you unclip the top part), and the entire thing comes apart once you release all the clip tabs with your screwdriver.
10. You will think the pump is stuck, but there are rubber grommets everywhere, so just wiggle it while pulling it apart.
11. Assemble in the reverse.
Took be me 15 minutes, including cleaning up a gallon of fuel from the floor, and killing a bottle of Black and Tan.
Didn’t take any pics as I just wanted to button everything back up, the fuel fumes were owning my car and garage. Plus as usual, my cam battery is always dead.
P.S. Don't light anything up while doing this. I take no responsibility if you are mess anything up, or if you don't use common sense and blow yourself up.
The following 2 users liked this post by slickgt1:
enshiu (10-03-20), gregh48 (01-05-18)
Old 04-28-09, 03:26 AM
Emil
Emil's Avatar
mods - please move to the "how to" section
Old 04-29-09, 10:51 PM
pingu
pingu's Avatar
There is no how-to section. :P
Old 04-30-09, 07:29 AM
slickgt1
slickgt1's Avatar
Really why not? I was planning on taking pictures with my friends swap this weekend. We should get the mods to make a how to section.
Old 04-30-09, 08:55 AM
Debonair
iModerate
Debonair's Avatar
Post a link to this DIY on the Hello all (Links to most DIYs for the GS) PLEASE LOOK HERE BEFORE YOU SEARCH!! "Sticky" thread and Nigel (nsf0607) will get it added to that insane list he created and maintains.
Nice work on the write up by the way. Pics will definitely add some value to this already useful DIY.
Old 04-30-09, 08:59 AM
Emil
Emil's Avatar
thats what i meant sorry the DIY section
Old 04-30-09, 10:19 AM
sam430
sam430's Avatar
Take pictures and pm nigel once you completed. I'd like to see the filter status (how clean or clogged it is and what mileage the car is at). Thanks for adding to DIY.
Old 04-30-09, 09:53 PM
slickgt1
slickgt1's Avatar
No problem at all. I will try to finish this soon. Thanks all.
Old 06-25-09, 12:45 PM
SorrGwa
SorrGwa's Avatar
Ill post up some pics i took when i changed my fuel filter
Under the rear seat, driver side w/ metal plate removed (held in place with 3 plastic 10mm bolts)
Fuel Pump Assembly
New Fuel Filter
Old 07-17-09, 06:15 AM
slickgt1
slickgt1's Avatar
cool. I actually did another swap and have a ton of pictures. I will do a writeup soon. Where do I host the pictures?
Old 07-17-09, 09:01 AM
vwynn
vwynn's Avatar
photobucket, i use.
Old 07-17-09, 10:00 AM
lo_dit
lo_dit's Avatar
looks like a pretty straight forward DIY. pics would be great!
Old 07-17-09, 10:34 AM
McKrevice
McKrevice's Avatar
subscribed
Old 07-17-09, 11:10 AM
esolo98
esolo98's Avatar
Nice DIY
How often should I change it?
Old 07-17-09, 11:52 AM
vwynn
vwynn's Avatar
well u shouldnt really need to change it often... unless your using dirty gas.. but i guess if u must change it.. change it with your timing belt service
Quick Reply: Simple Fuel Filter Change How to.
