high mount stop light bulb size
Old 11-06-09, 08:37 AM
sakataj
sakataj's Avatar
Originally Posted by 5t341th
hey, how do u get to the high mount anyway?
i cant seem to find a way to get to the bulbs.
do i go from the back seat?
??? have u ever turned your head while your in your gs, like before you change lanes? its sitting on the deck back there
i looked in the trunk and i dont see a way of reaching the highmount
its inside the car
Originally Posted by SorrGwa
you mean the 3rd brake light thats located at the bottom of the rear windshield?
you access it from the rear deck lid, basically slide the whole unit to one side and it should be able to be poped upward and out. then unplug the single plug there.
but this section is built up of 5 individual bulbs so may as well replace all while your there or do LED while your there
Old 11-06-09, 11:40 AM
5t341th
5t341th's Avatar
i know where its at.... i just need to know if i gotta remove the rear deck to get to it.
also, do i need to remove the rear seats to get the deck?
TIA
Old 11-09-09, 10:39 AM
sakataj
sakataj's Avatar
TIA
no, just pull it back a little then pull it up. it slides right out
btw these are leds i used in mine
http://www.v-leds.com/Exterior-LED/C...-p4481059.html
order 3 packs as u have 5 bulbs, you'll have a spare
Old 11-10-09, 10:56 AM
burny
burny's Avatar
Sweet, thanks
Old 10-19-10, 10:18 PM
LeXsGs3
LeXsGs3's Avatar
Default It worked!
Originally Posted by gsCrazy
alright it's finally fixed. i put in 168 bulbs in there instead of the 194s. i guess the wattage of the 194s was not high enough. the 4.9 watt 168s fixed it. the lexus owners manual states the bulb size is 921 for some reason.
thanks everyone!
i'm just going to leave a few key words below for ease of future searches.
2gs high mount stop light bulb replacement
2gs high mount stop light bulb size = 168
Thanks for this! although this post is over 4 years old, it still came in handy.
high mount stop lights replaced with 168's.
What was Lexus thinking? 921's don't even come close.
Old 10-19-10, 11:56 PM
YviE
YviE's Avatar
I had purchased some T5 7-LED bulbs on eBay. I have the same ones as parking lights and license plate lights for quite some time now. No bulb out warnings whatsoever.
Now I purchased 5 more for the high mount brake light. When I put these 7-LED bulbs in it triggers the brake warning light... It bothered me so much I just put back the original bulbs. (took me a while to figure out it were the bulbs, I had checked everything, fluid level, etc.)
I guess only the V-Led bulbs don't trigger the warning light.
Old 10-20-10, 10:18 AM
sakataj
sakataj's Avatar
i never said that....i had a bulb out warning light but i removed it.i never bothered to narrow it down to see if it was from my taillights or my high mount brake light as ALL my exterior lights (except my turn signals) are LEDS
Old 10-20-10, 10:29 AM
YviE
YviE's Avatar
I know you never said that. I just assumed you didn't have the warning light issue.
How did you remove it? Did you take out the bulb in the gauge cluster? If so, then you wouldn't know when the parking brake is on or not, right?
Old 08-29-11, 08:50 PM
ihateu3
ihateu3's Avatar
This thread is correct, the 168's do indeed work and correct the dash brake warning lamp. Its not that Lexus was wrong with the 921's, its that they are a different type of 921's or they have discontinued the original 921. The current 921's are "921 ST" or whatever the letters are afterwards. How do I know this? Because the lights I replaced where factory bulbs and they did say "921" on them followed by a single letter, cannot remember now but I think it was "F". These 921's that I replaced where also the correct size, while the newer 921's are larger.
Old 02-22-12, 07:24 PM
Hardrvin
Hardrvin's Avatar
Bump for solid info. Thanks for figuring out the bulb situation.
Old 08-23-13, 01:23 PM
PushinLEX
PushinLEX's Avatar
Which 168 red LED's did u buy again? The link referenced above no longer works.
Old 03-29-14, 11:47 AM
BBLexus
BBLexus's Avatar
Just replaced one bulb, oops - just became two. Key thing to note about removing the light is that you should push the whole unit toward the rear of the car then lift up on the end closest to you and then slide back away from the rear window.
I couldn't find 194 bulbs at walmart but I had two 2825 - 5W bulbs in a package in my glovebox I replaced the burned out bulb and then tested the unit before installing back in the car. One of the four original remaining bulbs in unit burned out when I tested so I had to replace another bulb. I tested again and all works well with no dash light indicator of a burned out bulb.
Is the 2825 bulb a suitable replacement for the 194?
gtoden1
07-12-24 06:41 PM
gtoden1
10-25-14 11:10 AM
safricags
11-26-07 12:23 PM
ChronoJ1
SC- 1st Gen (1992-2000)
22
12-12-02 09:20 PM
kevs
08-03-02 03:18 PM
Quick Reply: high mount stop light bulb size
