Which is better?
iModerate
Depends on how think you are going. At a certain thickness point the non stud spacers become unsafe because they will leave too little thread for the Lug Nuts.
The Stud spacers also make no sense if you are only adding a few MM's as the original studs will have to be cut or replaced so the do not interfere.
what kind of wheels are you using? if stocks, i recommend 25mm front and 30mm rear as thats what im running
btw with my expereice, they're all safe. thickness should determine wether you need spacers with studs or using extended studs. i've seen more pics showing ball joint failures, then broken lugs from spacer usage [zero].
4play4dr
Suspension and Brakes
21
07-07-15 03:20 PM
Rich27
Wheels, Tires & Brakes Forum
03-31-09 11:00 AM
