Weird Sound from Speakers
Old 05-02-09, 05:55 AM
g5cubed
g5cubed's Avatar
Default Weird Sound from Speakers
I got a Pioneer D1 installed in my GS400 a couple of months ago (installed by prof). Everything was fine, but I decided to disassemble the system so I could make some adjustments to the bezel. I re-attached all the wires (Power, AV, GPS Ant-in, FM Ant-in). However, when I turn the key to II, I hear a static sound from all four of my speakers. When I turn the key to start up the engine, the static sound becomes much louder (whirr sound), it sounds almost like a motor spinning very loudly. The sound occurs regardless of the volume level, whether off or high. I am still able to play audio fine and it works perfectly fine.
Does anyone know what might cause this? Thanks
Old 05-02-09, 08:23 AM
timgs300
timgs300's Avatar
If it was not there before you took it all out, then I would first check all the connections and make sure the wires have not pulled out of the connectors part way.
Old 05-02-09, 11:53 AM
1SWTGS
1SWTGS's Avatar
check your grounding wire or RCA plugs might be touching metal.
Old 05-02-09, 12:16 PM
macd7919
macd7919's Avatar
Does the sound change pitch with the rpm of the engine?
Old 05-02-09, 06:14 PM
tom steele
tom steele's Avatar
1skcvc is right check your ground first then rcas alot of people ruin there rcas when pulling them off the cheap ones are the worst and if a shop did it they probably used cheap ones 99.9 percent of the time they do unless you request better ones
llewatson
LX - 3rd Gen (2008-2021)
16
12-01-21 03:07 AM
hsmac
02-17-16 06:20 AM
mcamson
12
09-04-11 12:30 AM
g5cubed
05-02-09 10:17 PM
Quick Reply: Weird Sound from Speakers
