My Rears RUB... what to do..
Old 05-04-09, 02:35 PM
eyecon7
eyecon7's Avatar
Default My Rears RUB... what to do..
So i put my rims on this weekend Cut my fenders.. but not all the way. im not getting the stance i want.. what to do.. Im on HKS coils.. when dropped all the way looks tight but cant Move... and thanks Shawn(lexusondubs) for the Tires
Old 05-04-09, 02:48 PM
AsGs300
AsGs300's Avatar
Dude your car looks nice post a pic of the sideview, as fas as rub issue? i've heard that rolling em always works, good luck , sorry couldnt help out more
Old 05-04-09, 02:57 PM
ceelo
ceelo's Avatar
Keep the fat chicks out of the back seat and you should be fine
Provide the wheel size and offsets along with the brand and size of your tires. That might help us determine why its still rubbing.
Old 05-04-09, 03:06 PM
iKon_RX
iKon_RX's Avatar
roll and pull/flare it out the fenders.
Old 05-04-09, 03:16 PM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Rolling won't get as much clearance.
You already started to shave, so just shave the lip ALL THE WAY OFF.
Here’s the view of the inner fender lip shaved completely off.
Followed by a coat of primer, then paint or undercoat to suit.
If you still rub then, pulling, adding camber or tire stretching are your other options.
Old 05-04-09, 03:18 PM
Jedidiah
Jedidiah's Avatar
PM'd ya back.
Old 05-04-09, 03:40 PM
Anthony
Anthony's Avatar
Tire sizes?
Thats all the way down on HKS???
Hypermax?
Old 05-04-09, 03:42 PM
chrispy
chrispy's Avatar
Found your problem.
Old 05-04-09, 04:41 PM
speedaddic
speedaddic's Avatar
Originally Posted by chrispy
Found your problem.
word.... what chrispy said. If you shave all the way and the fender starts to split, you'll need to put some seam sealer in there so you don't rust out, a little primer, and undercoat
Old 05-04-09, 05:01 PM
handoverfi
handoverfi's Avatar
smaller tires? and camber ? but yea shave all the way
Old 05-04-09, 05:58 PM
4play4dr
4play4dr's Avatar
another white gs with sc1's..good thing ur not in cali
Old 05-04-09, 06:32 PM
ZippyGuy
ZippyGuy's Avatar
What's your offset, wheel size?
Old 05-04-09, 07:28 PM
eyecon7
eyecon7's Avatar
Didyou get this done by a shop.. and did it run you alot
i will once everything gets done straight
PM'd ya back.
PM UUU back
Tire sizes?
Hypermax?
235/30/20
255/35/20
maxxed out front
yes hypermax
im worried bout the barrel of the rim hitting the fender too.. it look like it would..
wheel size?
20x9.5 and 20x11
Old 05-04-09, 07:34 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
shave the rest of the way maybe heat for slight pull and thats about it you crack that dwp paint and its a ton to repaint soo be careful
Old 05-04-09, 07:45 PM
handoverfi
handoverfi's Avatar
go 245/35/20
Quick Reply: My Rears RUB... what to do..
