Question about SS You Zealand kit
From what ive searched on the forum, this kit will only work if you have coilover setup right? Can it be use to lower your car if you have stock suspension. I was going to get it on ebay to lowered my car using stock suspension but after reading a few threads on it, it seem that it only works with you already have coilovers. Can some one clarify that, thanks
i had the same question before, check this link.
https://www.clublexus.com/forums/sus...gs98-05-a.html
You don't need coilover. I would skip the youzealand and buy from Exact Motorsport or Todd in the vendor section. I would buy the front and rear. The front will drop about 1" and rear about 3/4" ..double check.
It's been asked many times... you don't need it coilover. But it's a good idea to get one. If your car is high mileage, more than likely your stock shocks are gone. It's a good time to buy springs and shocks...or go coilovers.
The RCA will lower any car with any suspension by the amount of its thickness. That is what they supposed to do. The benefit with using them with coil overs is you can elect to raise the coil over back up with the amount the RCA lowered the car, thus retaining the same ride height as you have before the RCA, but with less negative camber at that same ride height than before. If you choose to not raise your car back up, you simply will be lower with even more negative camber. You can even use RCA's with the stock suspension for about a 1" drop, and probably the stock camber adjustments will have enough room to keep you within OEM specs. That would be a perfect way to retain that smooth OEM Lexus ride with a slightly lower stance.
To add, I would buy front and rear together. Especially if you have stock HIDs with auto leveling. If you just get either the front or rear with out the matching axle, you headlights will be off and you'd have to make the proper adjustments from the leveling arms either in the front or rear lower control arms.
Master Thread Closer!!
You can use them on spring/shock setup. You will drop by 1", but by doing that...you will have negative camber. No adjustment for the front RCA...you just have to live with the added negative camber that comes from 1" drop. The important thing is that it corrects the geometry of the suspension...and maybe relieve stress to the Lower Ball Joint...which tends to fail on lowered cars.
Exact and SAGE rear RCAs have camber insert adjustments...so the rear camber can be "corrected"....even on spring/shock setup.
If you have coilovers, you can raise coilovers 1" to compensate for the 1" RCA drop....giving you the same height before and after RCA installation. Raising the coilovers will add positive camber...and allow for more suspension travel
(less chance of bottoming out)...and maybe less pressure/stress on the piston seals.
Back to the question about the You Zealand Body SS kit. Their rear kit (RCA) does NOT have any camber insert adjustment. You will lower the car by 1"...and live with the camber that comes with it.
If you use the RCA with the stock suspension, you can still adjust front camber via the stock camber adjustment bolt. The adjustment wont be a lot, but it should get you back within or at least close to stock specs as a 1" drop via RCA is basically the same as a 1" spring drop. As PHML mentioned, if you go with an RCA like Sage that has the camber offset inserts, you loose the stock camber adjustment bolt, but you gain fixed amount camber correction via the inserts.
