Rattling sound from the engine
I know i have to replace my Radiator because its leaking & replace my timing belt, sealer, thermostat gasket & water pump, And now my Power Steering pump also because it started to leak. This weird sound coming from the engine whenever i press the gas pedal, i can't figure out where its coming from but can someone help me out on this, im getting scared. I dont wanna drive till i get everything replaced but i want to know where the sound is coming from if its SERIOUS or NOT!?
Please Someone Help Me With This Problem?
it sounds like a rattling vibration when i press the gas on park, it still goes its just it makes that sound then its back to normal, & my power steering fluid still has half in it, but i noticed it's leaking under neath & now its getting into the timing belt, pulley, sealer & water pump so im not sure if thats why its causing it to rattle, but im waiting to see once i replace all the parts hopefully it goes away. I just have to wait for it to come!
I am going to go with the powersteering pump, my first gen gs300 is currently making a tapping noise too. The pump is leaking and by listening around it seems to be coming from from that area.
