My car still shakes at 65-75 MPH after.....
#32
Master Thread Closer!!
wheel hubcentric rings are a must. make sure they torque each lug nut in a star pattern...no air impacting. did you torque your lower ball joint nut to OEM specs? i'd also check the tires...since it may not be true round anymore...even with balancing. lastly would be the steering rack bushings.
#33
#34
that just means u werent fixing the right problem sir. i did do a road force balance but man it wasnt cheap either and i cant imagine doing it every 5k. **** that....even if you did it at work and didnt have to pay for it, doing it so often would annoy me too! im thinking of the bushing next...even though i hardly ever notice this anymore
#40
apparently i got lucky. i had the shakes really bad from around 60-65. read about a thousand threads about it and just figures with this happening to so many people that is was just a manufactures defect (the one side effect of owning this car (besides the lower ball joint)) then i got new tires about a month ago and did the wheel balancing and road force? done and now ihave NO shakes at all.
#41
just got done road balancing my front two and my steering wheel shake and front of car shake is gone. My passenger seat still shakes but i think thats just due to being on 19's + 35's and feeling more of the road. Everyone should do road balancing first before changing out things imo. I got brand new tires a couple weeks ago + balance and today after my road force balance the guy said my new tires were off by 3.5 ounces.
#42
update- its coming back it only shake now at high speed at around 65-70... what sjlex said i see my passenger seat shake like crazy when im by myself in the freeway... imma get my tires road balances again and pick up the hub rings tomorrow since i didnt have time today and see what happens... its really starting to **** me off alot =(
Changed out the rack bushings, ball joints, caster arm, wtf is next.......
#45
Someone suggested on another thread of the type of lugs your using. If your using acorn lugs then you may want to bore your wheels to put on the lugcentric lugs. I'm in the same boat as you guys. I just got MRR HR2s and their shaking like crazy between 55-66. Its driving me nuts.
