where can i purchase hubcentric rings??
05-14-09, 01:23 PM
called leswab and they told me to find my bore of my wheel... i dont know chit lol....
http://www.justforwheels.com/index.j...cat=hubcentric
cant seem to find my wheel manufacture, any help???
or anyone has the same wheels can lead me the right way in purchasing some correct rings please '
thanks
Riverside manufactures Altstadt im assuming but wth i cant find it haha
specs 19x8.5 / 19X9.5
Reason: pics
05-14-09, 01:45 PM
Well, the gs is 60.1
Post your wheel up...maybe someone will recognize it. You can measure the wheel yourself. It could be the normal aftermarket 73.1
You can also purchase it here if it's the normal aftermarket wheels.
https://www.clublexus.com/forums/clu...et-wheels.html
05-14-09, 03:48 PM
Where in CA are you from? I went to Mazz Motorsports in Alhambra
05-14-09, 04:18 PM
My Altstadt rims hub bore is 73mm, so more than likely yours should be the same. You would need hub rings that fit a 73mm outer diameter and the 64mm Lexus hub. Usually it will read 73mm OD and 60.1 or so ID.
05-14-09, 05:06 PM
Master Thread Closer!!
sounds like 73.1 and 60.1mm hubcentric rings
05-14-09, 05:45 PM
dubsonlexus
contact our sponsor adrain at b2bdesigns he can help you !
05-14-09, 06:15 PM
GS300ToM, it's pretty easy to measure it. I measure mine also last week, cuz I can't find any information of my wheels on internet. I can show you how, depends where you are in CA.
mine is 73mm & 60.1mm,
05-14-09, 06:31 PM
You need to measure exactly.....72.3mm vs. 73.1mm...are very close...but makes a world of difference in fitment.
05-14-09, 10:36 PM
got it 73.1 X 60.1, getting them tomorrow... ALUMINUM or PLASTIC same thing/ work the same right??
05-15-09, 04:52 AM
I recommend you go with plastic, because they don't rust.
05-15-09, 06:03 AM
Quote:
Originally Posted by
PHML
yeah gotta measure it
exactly .
and go w/ PLASTIC, at least that what I got.
05-15-09, 06:53 AM
picken it up after work....... will update soon
05-16-09, 04:21 PM
i had the same problem when i ordered my rims and i was off a tid bit..car shook abit. when i brought it to a rim shop and put the right ones in...man..shaking stopped.!!
rayac88
09-05-12 12:03 AM
energie8
06-02-11 07:06 PM
IS350ISFUN
05-20-06 06:47 AM
Dx3
08-08-05 09:27 AM
lex430
Wheels, Tires & Brakes Forum
10-06-01 02:14 AM
601 ,
601mm ,
731 ,
731mm ,
73mm ,
buy ,
centric ,
diameter ,
hub ,
hubcentric ,
is250 ,
lexus ,
outer ,
ring ,
rings
