anyone shave fenders past the spot welds?
Old 05-20-09, 11:19 AM
excluesive
excluesive's Avatar
Default anyone shave fenders past the spot welds?
Are you able to shave past the spot welds, THEN PULL the fender, without ruining anything?
I was to shave the fender lip flush, then pull. PLEASE HELP!
Old 05-20-09, 02:52 PM
excluesive
excluesive's Avatar
anyone??? (other than the people I've already spoken to)
Old 05-20-09, 09:59 PM
Spyder78
Spyder78's Avatar
yes I've shave the fender past the welds and than had to bring it to the shop to get rewelded as the outer and inner skin had seperated.
Old 05-21-09, 06:51 AM
excluesive
excluesive's Avatar
anyone else with the same issue?
Old 05-21-09, 07:07 AM
ceelo
ceelo's Avatar
I would have to believe that if you went past the spot welds and then did a pull that you would have to have it re-welded (just like above). Once you go past those spot welds the structural integrity of the fenders has been jeopardized. Even if nothing happened right away, you should have a trusted bodyshop take a quick peak to make sure everything is okay.
Old 05-21-09, 08:09 AM
Infamous 1
Infamous 1's Avatar
If you gonna do it, make sure to get it welded back up. Good luck!
Old 05-21-09, 08:59 AM
excluesive
excluesive's Avatar
looks like I will only shave to the spot weld, then have them rolled, even though this will make it harder to get as much pull as necessary.
Old 05-21-09, 09:41 AM
GS300ToM
GS300ToM's Avatar
whats the difference from shaving and cutting?? what tools are used to shave or cuttin?
Old 05-21-09, 09:55 AM
excluesive
excluesive's Avatar
same difference
Old 05-21-09, 11:36 AM
GS300ToM
GS300ToM's Avatar
oooOOOOOooo
Old 05-21-09, 12:07 PM
macd7919
macd7919's Avatar
To shave the fenders use a potato peeler to trim the fender lip away. It makes a nice smooth surface afterwards.
To cut the fenders use a pair of industrial strength scissors to cut the sheet metal, this doesn't leave as smooth a finish on the inside but goes a lot faster.
Old 05-21-09, 12:17 PM
excluesive
excluesive's Avatar
potato peeler? scissors? can you show me links of the products that will work?
Old 05-21-09, 12:22 PM
macd7919
macd7919's Avatar
Here you go:
Old 05-21-09, 12:25 PM
oohpapi44
oohpapi44's Avatar
LMAO.... You asked
Old 05-21-09, 12:32 PM
beez43
beez43's Avatar
hahaha chris youre an idiot...
Quick Reply: anyone shave fenders past the spot welds?
