Which lightbulb is this? (01 GS300)
my left brake light went out today
![](http://img29.imageshack.us/img29/7462/lexusgs300400430spoiler.jpg)
the one circled in yellow (is it caller the outter brake light?)
i am wondering whats the name for the light bulb so i can pick one up?
also are LED brake lights worth getting?
ive read some bad reviews but has anyone had any good experience?
7443 and they come in packages of 2. You can replace the tail light and brake light while doing it as they both use the same bulb. 2 screws on outside and 2 screws under the curtain in the trunk.
thank you everyone
do i need red bulbs or clear ones?
hey shoei, my friend (non-CL member) was just telling me today how nice your car looks
I dont think they make red ones.
as far as i know, the coding for the light bulbs go (no letter extension after the number code sizing) is clear bulb. if it was like 7443NA, i believe these were amber bulbs.
but all bulbs are clear on the GS. for light output of different colors, they use a colored cover that surrounds the bulb in the housing.
replaced it
thanks everyone for the tips
apparently they dont make long life for 7443
or at least the shops i went to dont have them
btw any one used these LEDs instead?
http://www.v-leds.com/Exterior-LED/P...35731-1-2.html
try not to get the LED's, i got a set thinking it was going to work... it only works when you turn the lights on but when you brake, the bulbs do not illuminate. i have a 02 gs300 and i used the bulb for the "outer light" right next to the one you have circled instead. no difference in light output.
i get these ones..
http://www.v-leds.com/Exterior-LED/P...02214-1-2.html
exact ones im using for both brake lights on the outer...
i used the v-stars on the inners or these...
http://www.v-leds.com/Exterior-LED/B...72892-1-2.html
you get them from vleds too?? i got the 7443's in white hoping they were the reverse lights but they are different in the 02 gs's. in jacksons led pictorial he used the 7443 for reverse and thats where i had a extra set. used them for the brakes and they dont illuminate when pressed for some reason, i tried again just now because of your post and same thing does not illuminate when pressed. :T
i checked last night, YES my brake lights light up when pressed! they are the ones i linked to in my post above
these are the ones i used for my reverse lights....
http://www.v-leds.com/Exterior-LED/P...82764-1-2.html
i even updated them on jacksons post for other 2001+ owners that the reverse lights use a 921 bulb i think
