Leaky b-pipe
So, I ordered a megan y-pipe to replace the factory one that the dealer said had the leak issue in
, install went smooth but the ******in light came back on today FML....
Car is going to the dealer on friday and I am having them fix it for good what ever the cost is, the GS is showing its age as we speak. It needs new tires, ball joints, this y-pipe issue etc etc. I am in talks with my local Acura dealer to see if I can just trade the damn thing for an 06 RL.
BTW here is what the megan y-pipe looks like.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
![](http://www.lextasy.com/images_products/is300_megan_racing_down_pipe_b1304.jpg)
CEL code is P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
The leak issue with the megan y-pipe was faulty gaskets, the exhaust shop installed old crush gaskets from OEM y-pipe so there was a leak where the headers met the y-pipe. I'll be getting the new gaskets installed today and resetting the code. Going to cross fingers/toes/***** to hope CEL dont come back :ugh:.
BTW, if it does come back, should I replace the above mentioned O2 sensor?
![](http://img33.imageshack.us/img33/9022/138498d1234369742checke.jpg)
As you can see from the above diagram that the the bank 2 has only one sensor on it which is before the cat so the only reason I can think the CEL code is coming on is due to a bad O2 sensor? Rather than engine malfunction?
Picture of the actual sensor
![](https://img200.imageshack.us/img200/1006/dscn5120.jpg)
This is where the wire from the sensor loops up and plugs into the socket.
![](https://img200.imageshack.us/img200/1760/dscn5121i.jpg)
Chidude23
04-14-14 09:38 AM
