Prefab sub box that'll fit my gs430 on the raised floor?
iModerate
sakataj- we are talking about a sub box that fits in the trunk in the raised section closest to the back seat right? if so the box in question is not a custon box for the gs. it is a single 12" bandpass box that is not ported. it is about 16-18" hight x 13-15" wide that fits perfectly in the raised section of the trunk. it only takes up about a 1/3 of the reaises section. i would serch q-logics boxes. i just had surgury on my foot so i am unable to take pics of it at this time, and i am not very good at uploading pics on this forum (i need a tutorial). i will describe it for you though: i mentioned the roughly the size of the box, it is black with a grey ring around the hole where the sub goes and a grey q-logic badge in the lower right corner. i hope this helps. if it is still kinda vauge pm your email and i will hoop you up with pics ( i can send them via email no prob haha)
Too bad you guys don't live in AZ. I'd build you all some bad@ss boxes at a great price
I built a 3.5cuft 4th order enclosure for my (2) 1000rms RE SX 10's. It fits perfect for height and width in the raised part of the trunk perfect, but protrudes out a bit due to it's size. But for a single 12 you would only need a 2.5cuft and it would sit flush on that raised section. Just in case you don't know what a 4th order bandpass is I'll let ya know... It's a sealed box connected to a ported box, the subs are hidden in the middle of the box. If you remove the factory sub you can fire the port directly up through the hole in the rear deck, this routes all of the bass into the cabin of the car and eliminates trunk rattle. Also 4th orders are very good for sound quality and if made right can gain 3db SPL.
Click the link in my sig to see the making of the 4th order.
Here is a vid of my (2) 10's in a 4th order...
http://www.youtube.com/watch?v=x82brWQLUPQ
Let me know if you guys need a quick design skteched out for ya with a cutsheet.
Northern California Regional Officer
Too bad you live too far from me Brian or I'd help you out, but let me know if you're ever in NorCal.
Single 12" with CF cover and custom mounted STB. I did it this way so that the trunk area would match the theme of my engine compartment.
My box is rectangular, with the CF cover on top.
Check out this thread: https://www.clublexus.com/forums/gs-...look-like.html
It's kind of old but I'm sure you can get some ideas from it. There's some in the that match the description you're looking for. My setup is on page 5, I'd suggest going custom over pre-fab, it looks good, and sounds better ...
https://www.clublexus.com/forums/3880110-post11.html
Found this on that thread, it's a very nice design layout that utilizes the factory sub hole...
that looks AWESOME glenn btw. what sub u running?
http://www.earthquakesound.com/subzero.htm
They were a $400-$500 sub back in 2006, it has 4inches of long throw excursion so this thing moves, would be amazing with a ported 4th order because you would feel alot more air moving and it would give girls in the back seat with long hair small afro, similar to how my 1000rms RE SX 10's do
Earthquake makes some badass subs too, I've heard the HoLeeS12
12" Elite Competition series and it was amazing for a single sub setup, can burp @ 7000rms...
http://www.lightav.com/car/earth/holees15.jpg
get 2 10 jl w6v2 with with jl sealed enclosure it fits pefectly in the raised floor you dont have to remove stock sub and it does not stick out.also sounds very very clean i highly recommend it. i have the same setup.
