ABS,VSC,Trac off lights on
05-30-09, 01:56 PM
just install tein SS and now all this lights are on. Can't figure out why. Any suggestions?
05-30-09, 02:54 PM
You probably yanked on the ABS sensor that's attached to the original shock body. When you re-install it, you need to make sure it's not pulling in any way when the car is on the ground. If you're lucky, it's repairable, otherwise you need a new sensor.
05-30-09, 03:15 PM
yeah...... thats probably what happened... i made sure my had clearence when i bolted it up to the shock body
05-30-09, 07:54 PM
100% thats what happened...
05-30-09, 08:21 PM
yes abs sensors definitly
05-31-09, 05:44 AM
Thanks guys, I will check them out and make sure they are not pulling. How can I reset to make the lights go off?
Reason: misspelling
06-01-09, 09:45 AM
Quote:
Originally Posted by
colombianc
um try this DIY for a fix...also TRY SEARCHING next time
http://www.projectgs.com/DIY/SuspBrake/ABSVSC/index.htm
06-01-09, 12:32 PM
06-02-09, 07:32 AM
colombianc
Thanks...will do.
no porblem
Gustavo621
Suspension and Brakes
02-02-19 06:13 AM
Bworley626
04-02-14 12:12 PM
dwb
07-22-13 06:15 AM
Emendoza
09-14-12 03:57 PM
11-20-01 05:06 PM
09 ,
1999 ,
350 ,
abs ,
absvsctrac ,
brake ,
forums ,
gs300 ,
lexus ,
light ,
lights ,
problems ,
rx ,
trac ,
vsc
