Very weird innter tire wear
Old 05-31-09, 11:49 AM
truenoboy
truenoboy's Avatar
Default Very weird innter tire wear
I went to change my front brakes yesterday only to discover that the insides of the tire are eaten out. Below is my suspension setup, wheel setup, and pics. Is this normal, and how can I correct this problem? It almost looks like wear from the upper ball joints, however I almost an inch clearence and don't see how the wheel could recoil up and rub it.
Specs:
- DF210 springs
- KYB G2R struts
- 235/30/20 front tires
Old 05-31-09, 11:53 AM
VNN326
VNN326's Avatar
that looks like straight camber wear. how long has it been since you got new tires? how often do you drive? btw if it hit the uca, you will probally see cuts and chunks missing.
Old 05-31-09, 11:59 AM
5t341th
5t341th's Avatar
that looks like regular camber/toe wear.
time for new tires and an alignment.
remember, even with daily use, your alignment will get out of specs over time
truenoboy
truenoboy's Avatar
Default Very weird inner tire wear
Specs:
- DF210 sprint
- KYB G2R struts
Old 05-31-09, 12:24 PM
GS300ToM
GS300ToM's Avatar
thats a really bad negative camber wear and outta spec toe haha...
Old 05-31-09, 01:16 PM
RICHYRICH
RICHYRICH's Avatar
I have a similar set up and, from what the alignment shop tells me its from camber and toe wear!
Old 05-31-09, 01:40 PM
4play4dr
4play4dr's Avatar
camber wear
Old 05-31-09, 02:25 PM
whazzzzuup
whazzzzuup's Avatar
This is a side effect of having a lowered car. To minimize this, a proper alignment (toe and camber setting closest to 0 as possible) is needed. Also, flipping the tires (remounting the right tire on the left wheel and vice versa), will prolong these wear characteristics. You do not need to worry about the upper control arm; it moves up along with the wheel when the suspension is compressed.
Old 05-31-09, 05:10 PM
GS4_Fiend
GS4_Fiend's Avatar
If you have a camber kit. that is the reason why.
Old 05-31-09, 08:03 PM
kit cat
kit cat's Avatar
not only camber but toe.
Old 05-31-09, 10:21 PM
PHML
Master Thread Closer!!
PHML's Avatar
You need new tires.....then get 4-wheel computerized alignment done ASAP....like everyone...I suspect negative camber and too much toe in.
You pointed out the upper arm knuckle...yours look considerably long in length...mines seems shorter. Check to see if its torqued properly....or needs replacement.
Old 05-31-09, 11:49 PM
GS4_Fiend
GS4_Fiend's Avatar
Larger rims, camber kit, spacers, anything that modifies the suspension such as lowering will cause camber wear. You just have to deal with it or take them off. The UCA I would aim first, ball joints, and suspension have it checked. Alignment doesn't necessary fixes the problem all the times. You just gotta deal with the suspension first. GL.
Old 06-01-09, 10:47 AM
sakataj
sakataj's Avatar
time for rca's or camber kit....
Old 06-01-09, 12:12 PM
SoCal Cyco
SoCal Cyco's Avatar
i have ruffly the same same set up (df210's and 20's w/ 255/35-20) and mine looks nothing like that? truenoboy-when was the last time you got new tires, rotated them, or got an alienment? that looks really bad. at least you cought it before you had a blow out at speed.
for you experts how much would a good alienment save your tires, ie miles with alienment vs not alienment miles?
Old 06-01-09, 01:53 PM
raytseng
raytseng's Avatar
Depends how "bad" your alignment is.
Your alignment specs could be hard on your tires or gentle on them.
If you are racing a car, sometimes you want to set certain alignment characteristics that sacrifice tire wear for certain performance characteristics.
Most likely though, a "bad" alignment will cause premature tire wear with no performance benefit, and actually probably performance detriment.
A "bad" alignment can grind through your tires within a few thousand miles.
A standard alignment should cost maybe $60. If you're modified and need special adjustments from an alignment artist, such a shop might charge you $100 or so. YMMV.
Now compare that to $600-$800 for new tires as well as regaining some lost performance.
Quick Reply: Very weird innter tire wear
