Please Help! P0125 CEL won't go away!
ok..i just ordered that part from lexus, should be here tomorrow morning.
regarding the gasket..its like 2$ but non available..they have to order that part from japan..so looks like its a no go on that.
Hopefully you can re-use the gasket again..
Please confirm me on that though..
based on what macd said, this should bring the car out of the closed loop.
If somehow this doesn't get rid of the check engine light, where is the next spot to look?
lexus told me they don't even have that gasket in stock..so what am i suppose to do? has anybody re-used that before?
what choice do I have right now?
UPDATE:
Bad news!! P0125 is still on. I replaced the ETC yesturday and the light came back on.
Im going crazy!![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
The mechanic was showing me his history of cars he had worked on with the same code. 99% of them all had a bad 02 sensor...but mine all are new..not even 3weeks old.
When i looked at the chart on the diagnostics page...it said Fuel, ie: injectors etc..
So what now guys? any input? i've changed what you guys told me too..now what is left?
Only thing i can think of is Fuel filter and 8 new injectors..
Please help.
Im going crazy!
Please help.
Keep in mind that even tho u buy a brand new O2 sensor, it can also be bad as well... defective parts... bring it to someone that actually know what their doing and stop wasting your money!! Spend $75-$100 on diagnostics and you'll get your moneys worth then.... if they misdiag ur car then get a refund but most shop go with ALL data or Mitchell's diagnostic tips... as much money u spent on your car... i could of bought a new set of coilovers haha but GL on it tho...
Who installed your 02 sensor? Are you sure they installed the sensor in the correct area? I would suggest you find someone with a scanner that can read live data and see why it is not going into closed loop. That would be the easiest way to diagnose is with a scanner. If you are from Orange County, I can help you out.
