Please Help! P0125 CEL won't go away!
#31
Ok when i looked at the diagnostics sheet on the screen it said for P0125 cloosed fuel loop control, it had injectors and O2 sensors etc listed..but no ETC, he told me, most likely this isn't going to solve your problem..but i went ahead and did it anyway.
Now..as for the 02 sensors, i bought them brand new OEM denso..and the two fronts are same part #, two rears and same part #,
You can tell, the wires are smaller for fronts compared to rears, its pretty much idiot proof.
Im pretty sure its somehow my injectors.. i don't know why,
This experience has pretty much soured me, i've dropped $4500 since april in this car, including a full front end paint job and all maintenance work done..I also bought a 3.76 LSD brand new last August, so I think im gona sell this car soon and get something new.
So my 3.76 LSD will be up for sale soon on the classifieds![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
any more thoughts on what i should do now?
I changed the EFI sensor with new gasket as well..the plug and play one..and i even topped off the coolent as well..so i don't know what your saying? which other sensor? I was told there's one on the rad as well, but I was told by you guys to change EFI
I can't think of anything else..
#32
Something to check for.... I had the same exact code thrown a few months back and it drove me nuts as well. I changed (3) oem denso O2's and nothing changed, for me it turned out to be a short/break in the wiring near the o2 connectors. the easiest way to check for that is to get a voltmeter and check if you have power to begin with im not into electrical at all so i paid a mechanic 20$'s to do a quick volt test on the plug connectors & found my problem. they soldered the break and all is wonderful now, never again seen that p0125 again after.
if you search under my name youll see a old thread i created going nuts over this same code which gave everyone a headache the way i was *****ing about it lol :T
#33
I can't think of anything else..![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
#34
ki_soarer
Performance & Maintenance
16
08-02-11 12:21 PM
