Idle problem!! any suggestions
Ok,
lately my car has been feeling really sluggish and acceleration is not always there.... i got no check engine lights on....
sometimes when i start the car, the idle bounces from 900 - 400 and makes a weird vibration.
the problem also occurs when i turn the A/C on, i hear the engine shake and the idle bounces....
anyone know what might be wrong?
bad spark plugs? something to do with the A/C belt?
Thanks!!
Thanks!!
i would say Vacuum leak for sure if idles jumpin up and down... get some carb clean and spray around the manifold or where ever and if ill drop/goes up then there u go..... dont remember if it goes up or down haha
If the above doesn't work take a look here:
High engine idle speed (Poor idling)
1. A/C signal circuit (Compressor circuit)
2. ECM power source circuit
Low engine idle speed (Poor idling)
2. Fuel pump control circuit
Rough idling (Poor idling)
1. Compression
Hunting (Poor idling)
1. ECM power source circuit
Surging (Poor driveability)
1. Fuel pump control circuit
During A/C operation (Engine stall)
2. ECM
1. Compression
2. ECM
fortitude
11-21-15 11:27 PM
