Replaced fuel filter, now car wont start
Old 06-05-09, 01:15 AM
Och
Och's Avatar
Default Replaced fuel filter, now car wont start
2001 GS430. Just replaced the fuel filter, put everything back together, that car cranks but doesnt start. The fuel pump makes noise when ignition is turned on, so I assume its working properly. What are my possibilities?
Old 06-05-09, 01:20 AM
swat1727
swat1727's Avatar
doubl check fuel pump
Old 06-05-09, 05:51 AM
Och
Och's Avatar
Yeah, took everything apart twice, the pump looks good.
What the best way to find out for sure that the pump is working?
Old 06-05-09, 08:21 AM
timgs300
timgs300's Avatar
Filter on backwards?
Old 06-05-09, 08:59 AM
Spyder78
Spyder78's Avatar
I've had this happen before. They might have given you the wrong filter. In 2000 the filter assemblies changed so i your car was made in the late part of 2000 and not 2001 than you use a different filter that other GS430s. Attempt to reinstall the old filter and see if it works if it does they gave you the wrong filter. If they gave you the wrong filter what happens is that when you attempt to start the car, the fuel pump backs out o the filter so the gas isnt flowing down the lines but instead just getting spit back into the tank.
Old 06-05-09, 09:45 AM
SorrGwa
SorrGwa's Avatar
double check you put back or replaced the o rings.
when working at a mod shop, it took us 3hrs to diognose what someone else forgot to put back in.
Old 06-05-09, 09:47 AM
SorrGwa
SorrGwa's Avatar
and where is the fuel filter on the 99 gs300s?
i went to the dealership and they said they never did one before. it was attached to the fuel pump, and sold the unit together.
i was hoping he was just kidding...
Old 06-05-09, 09:59 AM
Spyder78
Spyder78's Avatar
it is attached to the fuel pump but it is sold separately.
Old 06-05-09, 01:55 PM
sam430
sam430's Avatar
Doesn't it take awhile for the fuel to travel through? Just throwing some ideas out.
Old 06-05-09, 03:53 PM
GS4_Fiend
GS4_Fiend's Avatar
If the pump works, then it must be the filter is not installed correctly.
Old 06-10-09, 04:20 AM
Och
Och's Avatar
Completely forgot to update this one... We got the car started the following day.
What happened was, there is a rubber o-ring on the old filter. The new filter didnt come with that ring and we overlooked it. Took that ring from the old filter, put it on the new filter, and the car started right up.
And just for everyone's info, the fuel filter replacement job is not difficult, but very stinky. Do it in a well ventilated area and have a bunch of disposable towels ready.
Old 06-10-09, 07:51 AM
Euro09
Euro09's Avatar
so where is the fuel filter in 98-00 GS 300?? is there a DIY for that ?
Andy
Old 06-10-09, 09:55 PM
skperformance
skperformance's Avatar
Inside the fuel tank
Old 06-10-09, 10:14 PM
sam430
sam430's Avatar
How bad/good was the filter you removed? Do you recommend members to change or forgo it?
Old 06-11-09, 10:02 AM
SorrGwa
SorrGwa's Avatar
thanx for the update! i just ordered a fuel filter off sewellonline. will install it sometime next week.
sigh, so much to do!! but should be fun trying to install them all.
- fuel filter
- brake master cylinder kit
- trd thermostat
- greddy timing belt
- greddy cam sprocket
hope to have it all done before winter is here!
Quick Reply: Replaced fuel filter, now car wont start
