Where's my oil??
Old 06-09-09, 09:33 PM
GS4_Fiend
GS4_Fiend's Avatar
True. A bad PCV will cause oil leak especially from the valve covers.
Old 06-09-09, 09:37 PM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by 3UZFTE
My 430 holds 6.5 qts, I'd assume the 400 is similar. I think 3 qts might be a bit much to lose, but 2 might be safe to say, I am thinking more like 1-1.5. Was the light red or orange? There are 2 oil lights, one to check the level, and the other is pressure. I don't think your having an oil pressure problem as there is no knocking, which <3psi would cause. I have a 92' LS4 when I was about .5 quarts low, the oil level light was on. Maybe my thinking is a bit off, but just like to get the wheels turning I guess. Lexus should do a good job of diag'ing the oil leak, it would say valve covers, upper/lower pans, do you notice any oil spots in the driveway?
IIRC, our cars don't have 2 oil lights. There is only one oil light and it's red. If you are reffering orange, you are problem talkin about the maintenance light which we don't have.
Old 06-10-09, 12:09 AM
ElitistK
ElitistK's Avatar
false. our cars do have two oil lights. orange for low level (next to CEL) and the red one (low pressure). I managed to trigger both on separate occasions.
it all comes down to how long you are going to keep your car for. if not that long then just keep adding oil until the engine gives out.
Old 06-10-09, 09:17 AM
3UZFTE
3UZFTE's Avatar
Alright, sorry 6.5 was too much. It's been a few thousand miles since I've done my own oil. So it's 5.5 with filter, I was off a little, I usually do about 6 qts because it's never at the full line.
As Elitistk said, there are 2 lights. There is a red light for oil when it's less then <5 psi, the second is orange that tells the operator that their oil is too low, and should be check. The reason why it's orange is because it's not like it's going to ruin your engine, if the red light is on, it will.
Old 06-13-09, 07:52 AM
Frankdorn
Frankdorn's Avatar
So after the car was parked a couple days on (more level) pavement, I checked the dipstick again before adding a quart to make it to the oil change. This time there was a tiny drip at the tip. I figured as long as the oil light was out, I'd leave it, and have the garage check it out as-is.
After the oil change was done, I asked if he found anything. He said it was a quart low (that's a BIG quart!), but didn't see any leaks, and I don't appear to be burning oil, so he figured the last oil change may've been a little short. He said to keep an eye on it.
No panic necessary of course--the car doesn't take HIS a$$ to work every day!!
Anyway, I checked the dipstick this time--I'm full now
Old 06-13-09, 08:40 AM
MrG4Life
MrG4Life's Avatar
Did you go back to the same Lexus dealership to have this checked out?
Old 06-13-09, 10:48 AM
Frankdorn
Frankdorn's Avatar
Actually no, I had to work so I changed the appointment to a local lube place.
Old 06-13-09, 07:06 PM
sakataj
sakataj's Avatar
funny i did mine today and it holds 5.75 quarts
Old 06-14-09, 01:46 AM
GS4_Fiend
GS4_Fiend's Avatar
Thanks for the correction. Never gave any attention to the cluster.
Old 06-14-09, 02:04 PM
3UZFTE
3UZFTE's Avatar
That's probably because you don't have an aux. oil cooler. I was wondering why I remember more than 6 qts. It's a hayden and it holds about .5-.75 of a qt as its for a 24,000 lbs. gross vehicle weight.
OP, hopefully you've solved your problem with a fresh oil change.
Old 06-14-09, 03:53 PM
sakataj
sakataj's Avatar
thought we had a oem aux oil cooler?
ThumperPup
ES - 5th Gen (2007-2012)
12-13-13 02:51 PM
amerquresh
05-11-12 06:39 PM
KingNasGS4
21
03-24-09 08:51 PM
ONe21
Maintenance
14
04-14-07 07:19 PM
nnnickkk
Performance & Maintenance
15
07-20-05 05:06 PM
Quick Reply: Where's my oil??
