205/50/17 ok for winters?
vs the stock 235/45's? The overall diameter is similar but they are just a fair bit skinnier. Wondering about stability of the car. I would be getting these tires for free and their new is why I ask.
Thanks in advance
Thanks in advance
iModerate
Roughly 1.20 inch narrower and 1 inch shorter*. They will work but will most likely look funny. I am not sure if they will negatively affect your ABS and Traction Control but I doubt its a large enough difference to do so.
*Only .2 In shorter - Thanks DarKnight for the correction - I must have mistyped something when i was calculating this.
Last edited by Debonair; 06-12-09 at 08:44 AM. Reason: Corrected measurment courtesy of DarKnight - Thanks!
i roll 215/60 16 winterforce tires during the winter. it looks like i go mud bogging. but boy do these tires ride comfy! i can swing the wheel back and forth between 10 and 2 o'clock positions and the car will still go straight lol. its a combo of the chunky tread blocks squirming and the soft sidewalls. in hard turns, they squeal and howl like nothing else ive heard before. i've never spun [unless i wanted to] or gotten stuck when the roads are snow covered.
going back to your topic, i think you would be fine. with that size. she would probably be more stable than mine due to the smaller [and probably stiffer] sidewall. and i wouldnt call mine unstable. plus since youre getting a good deal on it, i say grab them.
iModerate
i have some 225/45s on my OEMs.
http://forums.vwvortex.com/zerothread?id=4003674&page=3
the size you're looking at should fit. speedo/odo readings will be off, but the tire will mount.
pic for reference. a 205/40 on a 17x8.
![](http://img2.abload.de/img/fk452_205_40_8x17_cw71.jpg)
