stock air box mod idea??
I tried searching for this and couldn't find anything so sorry if this has already been discussed..
Would it be worth my time to try and port a hole somewhere in the stock air box of my gs400 and run a tube down near the fog lamp to ram more/cooler air into the stock set-up?? of course this idea would also be combined with a high flow drop in air filter of some kind..
I've heard that the design of our stock air box set up is really good so it seems like it would work even better with the added benefit of more/cooler air..
If anyone would like to chime in on this idea please give me some feedback because I have more than enough time to try this and would be willing to post the results.
Or if anyone has already tried this I would love to hear about your experience with it
you cant barely hear the sound unless u roll your window down..and yes the car pull stronger on the top end (around 80 90 mph)...Im pretty sure your will pull stronger cause your is V8 mine is just V6. I get u back on the glue thingy I forgot what it calls lolz but its hard like steel . you can see that I painted to black to match the airbox too...you should do it... it looks completley stock no one will notice unless you point out.
Andy
Andy
Andy
Andy
Andy
Yeah I think I'm going to go with a 3in hole in my box because I went to autozone today and they make a 3 inch plastic/expandable tube which would be perfect for this project and is only like $19.99 or something. I know plastic will be good to use because it won't get as hot as metals, thus cooler/ more dense air
I'm excited to try this and hoping for some solid results!!!
Andy
I've actually done something like this before. It was back in 2006-7 when I was part of the Spectre Performance "Power Adder" experiment when they were trying to make systems for particular cars.
The gains weren't enough and it didn't keep the CEL away so they decided to scrap it.
This shows their prototype style tubing down to the filter
This shows the tubing down to the foglight area
here is a front view with it on
and a shot of it closer right under the power adder decal
I agree with carbongs 100%! I did several "versions" of this type of mod about 2-3 years ago.
My experiences with my GS400. At that time only had the TM plugs, K&N FIPK intake and Borla exhaust
1st setup- bought additional mandrel bent 3.5" intake piping and adapters to "extend" my K&N intake down behind the passenger foglight; had to cut a 3.5" hole downward in the sheetmetal behind the headlight to fit piping. The air filter was just off to the right of the passenger foglight where I removed a piece of plastic/foam by the lower air dam. It gave a full ram air effect.
Pros:
-I feel like it lost low-end torque but "kicked-in all at once" once the RPM's started to climb; almost like a turbo feel and pulled nice up top and on the highway.
Cons:
-I was getting a cel perhaps because of the length and or diameter of the piping; i.e. too much air coming in and the MAF couldn't keep up. So it may have been making a lean condition on my car.
-Engine is now susceptable to hydrolock if I would run over a deep puddle or something as the air filter was only 6" from the pavement.
-Air filter get considerably dirtier MUCH faster because it is subject to more debris due to being so low to the ground.
***update***
I tried this mod again when I first installed my Apexi neo A/F controller last year figuring that it would "cure" the cel code with this setup. Nope, as soon as I re-installed this setup the cel went on within 10 minutes where before I was code free for roughly a full year previous to this. Decided to give up permanently on this mod.
2nd setup- Left the K&N FIPK intake setup as it was intended; filter under the hood. I made an enclosure (not out of metal because I wanted to keep the hot engine bay heat away) and boxed off a little area with just the filter portion in the box.
Pros:
-No loss in low-end torque but and felt a little something on the highway.
-No cel codes
-Looks clean under the hood
-Air filter stays cleaner, longer
Cons:
-Intake growl definitely muzzled; a lot quieter under WOT
Overall, I liked this setup but I took this custom "air box" apart for a re-design and never got a chance to finish it. lol
3rd setup- used the mandrel bent 3.5" intake piping that I used on my first setup and re-routed down behind the passenger foglight through the 3.5" hole cut-out previously made. The air filter was in the normal intake location under the hood and I simply boxed off a little area (creating a type of airbox environment) and had the piping go into this "airbox" from underneath. I figured that it would give a little more power up top on highway runs.
Pros:
-No loss in low-end torque but didn't feel any real difference at all either on the highway.
-No cel codes
Cons:
-None really, just was a PITA trying to keep the pipe secured on it's own as now it was NOT connected to the intake itself; it was just a pipe hanging there by itself trying to scoop up some additional air.
I figured I'd share my experiences to help out...GL!
Oh, to the OP like everyone else said you need MUCH bigger piping to make ANY difference.
Pros:
Cons:
***update***
Pros:
-No cel codes
Cons:
Pros:
-No cel codes
Cons:
