Need an idler pulley w/assembly
As the title states, I need an idler pulley w/assembly. Currently there are no less than 12 unanswered e-mails out to various vendors that have gone un-responded, so I thought I'd rely on the area where I always get answers - CL.
So, ilder pulley is an 10 rib pulley, the spacer assembly extends 1 3/8 inch from the supercharger plate and bolts holding the assembly mounts on the back of the SC mounting plate. The opening to the idler assembly back is 5/8 inch.
Any help you all can offer?
And yes, I contacted LMS and the blew me off.
Northern California Regional Officer
Do you have a picture of what you are talking about and what set up are you running, LMS?
Try the Vortech website.
http://www.vortechsuperchargers.com/product.php?p=
They have idler pulleys.
63
63
I can source the pulley all day long, it's the assembly that's causing a problem. I need the pulley with assembly. The assembly gaps the SC belt 2 inches from the mounting plate, which means that is comes with a 1' 7/16 (1 1/3/8 preferred with a 10 rib pulley) or more spacer.
A pic of what your needing would help us out. It is hard to picture what if your talking about idler pulley on engine or some where on a SC bracket. We assume your talking about a GS300.
When you say assembly do you mean the spacer that the pulley is on & the bolt??
If you can get the pulley and just need the spacer I know aguy that can make it cheap ( he made me one)
Is this what your looking for-
Dedik8d1
SC- 1st Gen (1992-2000)
09-02-11 09:12 PM
